#37 | |
Perhaps that is why they decided to put up minimal information in their English site, and tons of information in Japanese.
454 whp, 1.7 bar boost, pump gas, water/meth. 501 whp, 2.2 bar boost, pump gas + avgas, no water/meth. www.viosturbo.com - World's first 500 WHP 1NZ-FE |
#38 | |
The MAF signal can be clamped via the E-Manage tuning software, its a standard feature that comes with E-Manage. With an E-Manage Ultimate, you could even clamp the stock narrowband O2 voltage.
454 whp, 1.7 bar boost, pump gas, water/meth. 501 whp, 2.2 bar boost, pump gas + avgas, no water/meth. www.viosturbo.com - World's first 500 WHP 1NZ-FE Last edited by changchewsoon; 04-03-2009 at 05:28 PM. |
#39 |
I did not mean any blame, just requesting the information someone would need to decide if they want to buy it.
#40 | |
rice rocket
Drives: 05 Echo Join Date: Feb 2007
#41 | |
It works by blocking the stock O2 which is narrow band and sends an adjustable lean signal to the stock ECU to keep it from pulling fuel in a closed loop operation. You would need to have a wideband O2 sensor installed to use the E-Manage Autotune feature.
#42 |
Bathroom + Laptop = <3
See now heres the thing lol, you say you are using E-manage Blue, but talk about the Ultimate as if that is what we need to tune the car. If you are using E-manage blue, are you getting any CEL at all? and are you running a decent AFR?
If you are running e-manage blue is it running in limp mode? Theres so many questions, because you are really the only one so far who seems to have got things working correctly on the yaris with no CEL and correct AFR without using a standalone system! |
#43 | |
rice rocket
All i've been reading on the internet is that people are making/buying an o2 clamp. I'd imagine it's just a comparator or something feeding the lean voltage to the o2 once you're in boost, shouldn't be too hard to figure out how to make one.
#44 | |
Main reason why I went with a economic E-Manage Blue for the moment being is because I'm saving to upgrade to a standalone system once my forged internals arrive for the engine. I upgraded my Innovate LC-1 wideband 02 to LM-2 because it allows you to simulate a narrowband signal to the ECU separately from the wideband, thus fooling the ECU. By the way, I understand from some of the posts here that there is a difference between the JDM ECU and USDM ECU. I am not sure whether this could be one of the reasons why the E-Manage or any aftermarket piggybacks is potentially causing a CEL to be thrown its wired up. I'll try to share as much information I can, please do let me know if you inquiries on my current setup and I'll try my best to share it.
#45 |
Question for our install this morning... the manufacturers of the kit I bought tapped the block for the oil feed. We want to skip all that work and tap the pan. Any reason why that would be a bad thing?
#46 | |
Apologize for the confusion, a wideband O2 is exactly what I was trying to say regarding the wiring of E-Manage Ultimate which is for the autotune feature. An O2 clamp/simulator is mandatory, I missed out the wideband O2 simulator I'm using. It works by blocking the stock O2 which is narrow band and sends an adjustable lean signal to the stock ECU to keep it from pulling fuel in a closed loop operation. <----My LM-2 does the job. For the narrowband O2, like you said you could either clamp it or use a simulator. Personally, I think using a simulator is better as you could tune narrowband rather then clamping it at a fixed voltage.
#47 | |
Are you planning to tap the oil pan for both the feed/return of the oil for your turbo? I would recommend you to tap the feed from your oil pressure sender and tap the pan for your return. You want to do that to ensure your turbo gets the oil feed via a constant pressure. I too asked my tuner to skip all the work and tap everything right off the pan, his justification is that if we're driving the car in extreme conditions such as taking a hard corner fast, the oil inside the pan could be "pushed" against the side wall of the pan, and there is a chance of a vacuum being created resulting a situation whereby there will be a temporary cut of supply of the oil to the turbo. Not sure whether it makes any sense to you. Also, if we're tapping the feed off the pan we need to calculate the correct height. Too high we might not be able to guarantee a steady supply, too low we risk sucking up all the particles at the bottom of the pan, although you could minimize the risk by using a magnetic bolt nut or use a magnetic oil filter such as one from Power Enterprise. Alternatively, you can just use an oil sandwich adapter and add a pressure and temperature sensor for monitoring purposes as well. But I would recommend you to use the oil sandwich adapter for an engine oil cooler, as the oil will be warmer since it is shared by the turbo as well. It is really a good investment even you're not planning to take car to a track or down the drag strip. Just my 2 cents!
#48 |
Makes sense. The reason ZPI tapped the block was beause tapping the pan leaves that line exposed to road hazards. We will figure something out. Thanks!
#49 |
der Zeck
I hurt...... but doing chino's swap, the feed line is off the oil press sen on the front of the block and the return was tapped into the block just above the pan.... only down fall to tapping the pan would be that it hangs kinda low
oh yeah.... and I hurt
#50 |
aw don't worry, Joe, Charles will give you a lovely massage in thanks of your hard work
![]() But yeah now that I think about it, the return line, doesn't really matter where it sends up, right? It's not picking up fresh oil, just returning the hot one from the turbo housing...
#51 |
der Zeck
we got the return line tapped into the oil pan right next to the oil plug fine
all that needs done is running the e-manage, then it should be a-ok took us longer than we thought
#52 |
der Zeck
just to let everyone know Chino made it home with a fully boosted ride
#53 |
rice rocket
sounds great, lots of pictures! :)
any way you could pull the emanage maps ?
#54 |
der Zeck
he ran with the tune that was put in there from ZPI back when it was installed on the other car.... I am sure he is going to tweek some things, then get it retuned......
object this weekend was to safely get Chino home with his car
| Turbo Questions | regal | Performance Modifications | 0 | 03-27-2009 02:07 PM |
| Turbo Kit - trade for stock parts! | crankyelbow | Items for Sale by private party | 62 | 02-03-2009 12:30 PM |
| delayed turbo project... | joey1320 | Forced Induction Forum | 8 | 09-26-2007 11:18 PM |
| ZPI....I Have question's | punch | Forced Induction Forum | 15 | 07-02-2007 07:27 AM |
| Vitz Rs turbo vs U.S. Yaris add turbo? | weaponrcamry | Performance Modifications | 18 | 08-09-2006 08:45 PM |
