Originally Posted by taKuto
where does the emanage ultimate clamp O2? I'm looking at all the wires but none of them intercept the O2 signals.
You need to look up the wiring diagrams, E-Manage Ultimate has an auto tune feature which you set in a AF ratio and E-Manage will try to adjust itself to dial in the AF ratio set by you.
It works by blocking the stock O2 which is narrow band and sends an adjustable lean signal to the stock ECU to keep it from pulling fuel
in a closed loop operation.
You would need to have a wideband O2 sensor installed to use the E-Manage Autotune feature.
454 whp, 1.7 bar boost, pump gas, water/meth.
501 whp, 2.2 bar boost, pump gas + avgas, no water/meth.
www.viosturbo.com - World's first 500 WHP 1NZ-FE
