Old 04-05-2009, 01:20 AM   #11
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
Here is what I know about cable throttle bodies vs drive by wire systems:
Cable throttle:
-Very responsive and has been used for many decades.
-Connected to the gas peddle by a series of pulleys.
Drive by wire:
-Smooth acceleration.
-There is also noticeable lag when you press on the gas peddle because the computer has to tell the ECU how much the throttle has to open; not as quick as good 'ole cable throttle.
-Take a look at the gas peddle on a Yaris. Notice anything? There is a box to which a peddle sits in, connected to some electronics which lead to the ECU.
-When you drive over some speed bumps and you press on the gas peddle a little bit, the car wouldn't jerk or move violently in the event of sudden acceleration. This is meant for driving comfort.
THanks for your reply it is something that I didn't consider.
So if I consider to upgrade to cable throttle what parts exactly I need and how can I know if the ecu supports this feature?
Turbo Kit - trade for stock parts! crankyelbow Items for Sale by private party 62 02-03-2009 12:30 PM
delayed turbo project... joey1320 Forced Induction Forum 8 09-26-2007 11:18 PM
Engine Swap / Turbo.... Sabretooth Forced Induction Forum 10 09-13-2007 06:23 PM
small update on turbo project... joey1320 Forced Induction Forum 26 08-03-2007 04:29 AM
Vitz Rs turbo vs U.S. Yaris add turbo? weaponrcamry Performance Modifications 18 08-09-2006 08:45 PM
