Old 04-05-2009, 06:36 AM   #1
metalshark
MetalShark
Drives: 2008 Yaris LB
Microchip
Switch to a Microchip PIC microcontroller. Same or better functionality for <$5 max and many of the PICs can directly drive LEDs with the outputs.
For example the PIC16F57 is $1.55 and has 20 I/O Pins and runs at up to 20mHz. If you're not comfortable with C or assembly programming, there is even a basic compiler for the PICs.
http://search.digikey.com/scripts/Dk...IC16F57-I/P-ND
What is the equipment to get started with it run? I talked to a Microchip forum member this morning that is recommending the 16 bit PIC24/dspic trouble being that the starter kit is $300. On the up side the kit comes with a student version C compiler.
Absolutely red, Drawtite hitch, CAI, Insulated Header, Amsoil 5w-30, Mag-drain plug, Red-Line MT-90 tranny oil, Scotch-Guard, Window Tint, Dash rug, Custom short throw shifter, Lowered OEM arm rest, Super-Turbo muffler/w chrome slash cut tip., TRD rear sway bar, sticky pads, front shock tower bar, RS grill badge, VVT-i emblems, Second tire set from Tirerack.com, DISABLED DAY TIME RUNNING LIGHTS, platform- style locking custom bike rack. 86K miles so far. 5 years use now on ceramic wrapped insulated stainless-steel header.
metalshark is offline   Reply With Quote
Old 04-05-2009, 08:51 AM   #2
You can spend from $10 to $1000 to get going. You can download the student/evaluation versions of the compilers for free from Microchip's website. The purchased version adds optimization, but I seldom compile with optimization, as I find it often messes up critical timing.
$10 Programmer for many processors:
http://robokitsworld.com/index.php?m...fl6nbiqsr52nu0
$50 programmer (USB/serial):
http://www.hobbyengineering.com/H3317.html
Real Microchip programmers:
PicKit2 (directly integrates with Microchip's development system):
http://www.microchipdirect.com/Produ...mid=1&treeid=6
$220 Microchip In Circuit Debugger:
The latest version is the ICD3. I use the ICD2 for most of my development work.
http://www.microchipdirect.com/produ...?Keywords=icd3
To use the Pickit2 or ICD2/3 you have to add a header (or RJ11 jack) to your board to connect to. The two third party programmers allow you to plug the DIP package IC's in for programming.
P0456 OBD code? jlift DIY / Maintenance / Service 6 09-19-2007 03:28 PM
Anybody know the code? Driver New YARIS Purchase Forum 5 08-20-2006 06:56 PM
