Old 04-05-2009, 06:36 AM   #17
metalshark
MetalShark
Drives: 2008 Yaris LB
Microchip
Switch to a Microchip PIC microcontroller. Same or better functionality for <$5 max and many of the PICs can directly drive LEDs with the outputs.
For example the PIC16F57 is $1.55 and has 20 I/O Pins and runs at up to 20mHz. If you're not comfortable with C or assembly programming, there is even a basic compiler for the PICs.
http://search.digikey.com/scripts/Dk...IC16F57-I/P-ND
What is the equipment to get started with it run? I talked to a Microchip forum member this morning that is recommending the 16 bit PIC24/dspic trouble being that the starter kit is $300. On the up side the kit comes with a student version C compiler.
Absolutely red, Drawtite hitch, CAI, Insulated Header, Amsoil 5w-30, Mag-drain plug, Red-Line MT-90 tranny oil, Scotch-Guard, Window Tint, Dash rug, Custom short throw shifter, Lowered OEM arm rest, Super-Turbo muffler/w chrome slash cut tip., TRD rear sway bar, sticky pads, front shock tower bar, RS grill badge, VVT-i emblems, Second tire set from Tirerack.com, DISABLED DAY TIME RUNNING LIGHTS, platform- style locking custom bike rack. 86K miles so far. 5 years use now on ceramic wrapped insulated stainless-steel header.
metalshark is offline   Reply With Quote
P0456 OBD code? jlift DIY / Maintenance / Service 6 09-19-2007 03:28 PM
Anybody know the code? Driver New YARIS Purchase Forum 5 08-20-2006 06:56 PM
