Old 04-02-2009, 06:20 PM   #24
metalshark
MetalShark
Drives: 2008 Yaris LB
How responsive is it?
Originally Posted by CtrlAltDefeat View Post
I am very interested in this... If I read the schematics correctly it uses LEDs to show the revs... how responsive will this be? If it's cheaper then an aftermarket tach and can be made to look good I would love a DIY tach... trying to think of where would be best to put the LEDs...
The BS2 chip scans at 20,000 cycles per second on its clock. The entire code is less than 100 lines. The output display driver section is a rather primitive analog/linear op-amp arrangement but it is very fast. This design is WAY faster in its response than any mechanical tachometer needle can possibly be. The code uses the pulsein command for data and in a worst case situation will generate an accurate RPM number in one revolution of the crankshaft.
Absolutely red, Drawtite hitch, CAI, Insulated Header, Amsoil 5w-30, Mag-drain plug, Red-Line MT-90 tranny oil, Scotch-Guard, Window Tint, Dash rug, Custom short throw shifter, Lowered OEM arm rest, Super-Turbo muffler/w chrome slash cut tip., TRD rear sway bar, sticky pads, front shock tower bar, RS grill badge, VVT-i emblems, Second tire set from Tirerack.com, DISABLED DAY TIME RUNNING LIGHTS, platform- style locking custom bike rack. 86K miles so far. 5 years use now on ceramic wrapped insulated stainless-steel header.
metalshark is offline   Reply With Quote
P0456 OBD code? jlift DIY / Maintenance / Service 6 09-19-2007 03:28 PM
Anybody know the code? Driver New YARIS Purchase Forum 5 08-20-2006 06:56 PM
