Old 04-10-2009, 02:36 PM   #1
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
If I do find my coolant's down like yours, I'm going to immediately top it up!
Old 04-13-2009, 08:40 PM   #2
CB900F2
Drives: 08 Sedan
Hilton.. Did you have a chance to pop your coolant cap and take a look at the level? (cold)
thanks
CB900F2 is offline   Reply With Quote
Old 04-14-2009, 11:10 PM   #3
Yaris Hilton
Smile
thanks
Nope. Haven't. Guess I'd better.
Old 04-18-2009, 03:23 PM   #4
CB900F2
Drives: 08 Sedan
Bump... Whats up guys, nobody wants to take a quick peak in your coolant filler neck??..
Are you scared of what you might find
P.S.. Check it when the motor is fully cooled down..
Old 04-18-2009, 07:01 PM   #5
kurokoma-kun
Drives: 2007 Yaris HB
Truly, why not? It's one of the easiest vital fluids to check... and its worth a look, I was very surprised to see how little coolant was in my reservoir tank before I topped up.
Now in my case I found I had somehow knocked the reservoir cap slightly open as I worked--just about a week later quite a bit of coolant had evaporated. The level being at or below the neck of radiator hose however, seems to be normal for me, its been that way every time I've checked.
Old 05-03-2009, 09:45 PM   #6
Yaris Hilton
Smile
I did eventually look and found that all three of my family's Yarises have the system working properly, with the radiator neck full up to the cap, no air space, and the overflow bottle filled about halfway when cold.
Old 07-23-2009, 07:02 PM   #7
CB900F2
Drives: 08 Sedan
Hilton/All...
Do you think there might be an air pocket or a defective rad cap??
Hilton.. If I understand your responce, does your overflow bottle rise to the full mark when the motor is warmed up and will then drop back down to the half way point of the overflow bottle when the motor cools?
I have ask the same question on another forum and few yaris (sedan) owners and they all have the same situation. Very odd...
Help ASAP!!!! low coolant indicator MeggiemobileSFLA DIY / Maintenance / Service 29 08-03-2013 01:09 AM
Coolant Service N9QGS DIY / Maintenance / Service 31 11-27-2012 06:55 AM
Coolant level when engine cold CB900F2 DIY / Maintenance / Service 4 04-05-2009 11:12 AM
Proper coolant level? jay DIY / Maintenance / Service 4 03-22-2009 04:23 PM
GET FREE PS3/360/Wii check it out! marcus Off-topic / Other Cars / Everything else Discussions 23 09-25-2007 06:51 PM
