Old 04-05-2009, 08:15 AM   #1
CB900F2
Drives: 08 Sedan
Coolant level when engine cold
Hey guys.. With your yaris, when the motor if fully cooled down from a drive, and with the car not running, what level do you find the coolant at in the filler neck?..
thanks guys!
CB900F2 is offline   Reply With Quote
Old 04-05-2009, 08:23 AM   #2
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
when the engine is warmed up, I top the coolant off to the full mark. it doesnt settle that much from the full mark. I dont think you have to worry about it for a while, unless you are leaking cooling, I have only added coolant once in 60k miles of driving.
Old 04-05-2009, 08:49 AM   #3
CB900F2
Drives: 08 Sedan
Hi Alex.. I assume you are referring to the overflow bottle... I am wondering at the filler neck that is connected to the rad hoses..
Thanks Alex...
Old 04-05-2009, 09:02 AM   #4
AlexNet0
AlexNet0's Avatar
ohh, when mine is cold, and I open the cap on the radiator hose, its down to about the top of the hose, not yet up into the little neck that the cap sits on.
Old 04-05-2009, 11:12 AM   #5
^ but it's not a bad idea to top it off before closing it again. You shouldn't have any air in there.
Proper coolant level? jay DIY / Maintenance / Service 4 03-22-2009 04:23 PM
Cold Engine and Gear Shifting captainm27 General Yaris / Vitz Discussion 9 01-29-2009 08:27 AM
GET FREE PS3/360/Wii check it out! marcus Off-topic / Other Cars / Everything else Discussions 23 09-25-2007 06:51 PM
