Old 04-13-2009, 08:19 PM   #1
Lafiro
Drives: 06 Yaris Sedan
Ok, I will check this in the morning then, but the question remains,
is the reason why the e-brake being so loose now because the rear drum shoes are worn down a lot?? Or Does the e-brake line have to be adjusted itself every once in a while?
I know in my dads car, I pull it half way up, and the rear wheels lock easy.
This car, you can pull with all your might, and the rear will NEVER lock up.
DIY (sorta) - RunStop Rear disc brake conversion eTiMaGo DIY / Maintenance / Service 17 07-02-2019 08:24 AM
DIY INSTALL/REVIEW: Dezod X-Rated Yaris Brake Pads ChinoCharles DIY / Maintenance / Service 40 10-13-2017 05:23 PM
DIY Rear Drum Brake Adjustment/Parking Brake W/ PICS Inside YarisSedan DIY / Maintenance / Service 73 03-11-2017 06:05 PM
BIG(GER)TM BRAKE KIT Vanderkitten Performance Modifications 23 01-04-2009 07:16 PM
Parking Brake Geelmeel General Yaris / Vitz Discussion 3 06-07-2007 11:06 AM
