Old 04-14-2009, 10:28 AM   #1
TheSilkySmooth
TheSilkySmooth's Avatar
Drives: 08 3DR 5M Bayou Blue; 09 Fos
May need a new cap. Make sure the rubber gasket is clean. And only open that rad when cool. Try running heat on high and fan on hi to get the fluid circiulating through the heater core - that may move a bubble.
TheSilkySmooth is offline   Reply With Quote
Old 04-14-2009, 06:56 PM   #2
CB900F2
Drives: 08 Sedan
Are you able to pop open your rad cap when your motor is close and take a look at the coolant level and let us know what you find?
thanks TSS
Help ASAP!!!! low coolant indicator MeggiemobileSFLA DIY / Maintenance / Service 29 08-03-2013 01:09 AM
Coolant Service N9QGS DIY / Maintenance / Service 31 11-27-2012 06:55 AM
Coolant level when engine cold CB900F2 DIY / Maintenance / Service 4 04-05-2009 11:12 AM
Proper coolant level? jay DIY / Maintenance / Service 4 03-22-2009 04:23 PM
GET FREE PS3/360/Wii check it out! marcus Off-topic / Other Cars / Everything else Discussions 23 09-25-2007 06:51 PM
