Old 04-20-2009, 11:54 AM   #1
fuji
fuji's Avatar
Drives: Polar White Yaris HB
I feel a more effective alternative is a oil filter magnet. Check out filtermag.com
fuji is offline   Reply With Quote
Old 04-20-2009, 02:49 PM   #2
schleppy
I love momentum.
schleppy's Avatar
Drives: 2009 Yaris LB, Red
My only concern with a filter magnet is that if enough gunk were to build up in the filter, the magnet would hold it all in the filter in the spot with the magnet. It could potentially reduce the flow of oil.
The drain plug isn't in such a crucial flow path.
Garm: The no phone number thing is odd, but they answered my e-mails fast, and I'm sure they would give you their number if you genuinely needed to talk to them.
Old 04-21-2009, 12:04 AM   #3
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
If you've got that much metalic "gunk" building up in your filter, you've got far worse problems to deal with.
PetersRedYaris is offline   Reply With Quote
Tags
magnetic drain plug ap03
Oil drain plug gasket question schleppy DIY / Maintenance / Service 7 04-17-2009 05:35 AM
motor oil drain plug washer xpeteyjtx DIY / Maintenance / Service 13 12-30-2008 01:27 PM
Oil Drain Plug Size? Nigal DIY / Maintenance / Service 4 05-31-2007 01:55 PM
Magnetic Drain Plug Source? blacksan DIY / Maintenance / Service 9 05-11-2007 08:01 AM
