![]() ![]() ![]() ![]() Drives: 2008 yaris, stripped, red Join Date: Jan 2009
run the oem wattage bulbs. anything higher than oem wattage will hurt wiring.
#2 | |
The Hated One
Drives: 07 White Manual Sedan Join Date: Sep 2006
also, from my experience, a bulb that pulls a few more watts than factory wont fry a harness, but if its alot more, expect problems. It is just like any other wiring, including home electrical. the wires in your house leading to your light bulb fixture are meant to have a certain amount of current running through them...if your home fixture recommends a 45 watt bulb, if you put a 120 watt bulb in it, expect the socket wiring to melt or the wires leading to the socket to melt and cause a fire. same deal with your car. will a 5 watt higher bulb ruin the wiring harness? doubtfull, but if it does, dont expect warranty coverage and expect all the naysayers to say "i told you so"...
| Changing LED's In Projector Head Lights | whooppee777 | Cosmetic Modifications (Exterior/Interior) | 16 | 03-01-2009 02:07 PM |
| Changing the oil | lita_g | DIY / Maintenance / Service | 18 | 10-28-2008 01:59 PM |
| Changing Headlight Bulb Tutorial | RSboyz | DIY / Maintenance / Service | 29 | 03-15-2007 01:35 PM |
| About Engine Oil Changing Manual | hans_fh | DIY / Maintenance / Service | 4 | 03-03-2007 10:20 AM |
| Changing to 60/40 seats? | NickNickNick | General Yaris / Vitz Discussion | 1 | 05-14-2006 04:08 PM |
