454 whp, 1.7 bar boost, pump gas, water/meth. 501 whp, 2.2 bar boost, pump gas + avgas, no water/meth. www.viosturbo.com - World's first 500 WHP 1NZ-FE |
![]() ![]() Drives: 04.:R32, 87 Scirocco, 07 yaris Join Date: Apr 2009
that twin charged yaris is awesome.
until i saw that i was going to say that it is totally possible, possibly using mega squirt or another stand alone system to run the fuel/spark and avoid the tricky stock yaris ECU. VW currently makes a production 1.4 twin charged engine making 170hp. also some guy in denmark(i think) made a custom supercharged/turboed 1.8t GTI making 500hp. he actually used 3 ECU's to run the car: 1 for the turbo, 1 for the supercharger, (running 8 injectors) and 1 for the rest of the car. i could only imagine what a no lag 500hp would feel like |
#3 | ||
I used to have 1700 posts
So i emailed brash boys the responded very quickly. heres my inquiry followed by their response.
"I noticied you guys make a dual charged kit for the yaris. I have Yaris with the Blitz Supercharger and naturally I want more power. I was Curious if you could inform me as to what size turbo you use in your kit, how much boost does the turbo makes, how much additional boost can the Blitz supercharger handle, and I was curious if it would be possible to get a copy of the Installation manual for the dual charged kit. I would even pay for the manual, just so i could get some sort of idea of how to route the piping, even though the chasis codes are not the same it would help a lot. Thanks" "Hello. Our dual charger does not sale by kit model, sorry. Engine; Forged connecting rods Forged low compression pistons Forged valve and valve spring Power FC Boost 1.0k 270HP If install the sleeve in the block, will go up boost 1.2k, over 320HP." So now the search begins for sourcing and pricing Forged Connecting Rods, Forged Low Compression Pistons, Forged Valves & Valve Springs, Standalone Engine Management, a place to sleeve the block, turbo exhaust manifold, turbo, and a way to fortify the crank just to be safe, fortified axels. plus anything else i forgot |
The Quest Begins
Used 1NZ-FE Engine
Junk Yard $ Cheap As Possible Turbo Manifold http://www.365motorwerks.com/turbomanifolds.aspx $375 Turbo ? ? Forged Low Compression Pistons ? ? Sleeved Block ? ? Forged Connecting Rods ? ? Forged Valves & Valve Springs ? ? Fortified Axles http://www.yarisworld.com/forums/sho...highlight=axle ? Fortified Crank ? ? Standalone ECU ? ? The other necessities will be added once the above is sourced |
| Electrical System Upgrade Advice | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 03-23-2016 01:15 AM |
| So... twin DIN install. (NOT Double DIN) Is it possible? | WolfWings | In Car Entertainment + Electronics (audio / video / alarm) | 15 | 04-01-2009 08:49 AM |
| Twin engine Yaris. | ddongbap | Off-topic / Other Cars / Everything else Discussions | 18 | 12-15-2008 10:54 PM |
| Twin Charge!!! (the best of both worlds) | DollaZo | Forced Induction Forum | 51 | 11-15-2008 01:07 PM |
| JDM STABILIZER CHARGING SYSTEM | ketel0ne | Performance Modifications | 15 | 09-13-2006 08:56 PM |
