STALK: 84140-52151
RELAY: 90080-87026 SHROUD LH: 81482-52260 SHROUD RH: 81481-52330
EVERYBODY EVENTUALLY COMES BACK TO YARISWORLD...... Last edited by BLAZINBLUEVITZ; 04-21-2009 at 01:14 PM. |
fixed......
EVERYBODY EVENTUALLY COMES BACK TO YARISWORLD...... |
![]() ![]() ![]() ![]() Drives: 2009 Yaris Hatchback Join Date: Feb 2009
That's what I figured. Is it this one? http://shop.microimageonline.com/pro...&productId=111
Will this kit work with the '09 3 door LB if I get the shrouds from Toyota? |
#9 | |
The OEM trim pieces are the only thing needed to make it work on an 09. |
#10 | |
![]() Drives: 2010 sedan Join Date: Sep 2010
Oh, and is there an OEM toyota part number for the foglight wiring harness? I assume that with the new foglight stalk, there is no need for an interior wiring harness. |
#11 | |
everything is in the kit apart from the OEM Stalk which is not required , and the whole kit is nplug and play |
| Compilation of Yaris How-tos/DIYs | YarisBueller | DIY / Maintenance / Service | 39 | 04-28-2018 08:47 AM |
| Fog light install | 07yaris_fe | Cosmetic Modifications (Exterior/Interior) | 10 | 07-20-2010 01:18 PM |
| Looking for the Toyota Fog Light install | RocknRollRon | DIY / Maintenance / Service | 33 | 06-13-2010 06:46 PM |
| srs / airbag light after head unit install? | KwonSau | In Car Entertainment + Electronics (audio / video / alarm) | 7 | 12-24-2008 02:04 AM |
