Giupo,
I'm currently using the E-Manage Blue for my turbo, and the MAF volt is clamped at 4.95v. Do you have a MAP sensor as well? If budget permits, you may want to add a MAP sensor as another input for your Ultimate and tune your car off its reading as well. You can achieve a much more accurate tune with a MAP sensor rather than relying on the TPS readings. But in your case, you have the boost harness as well, which is cool. If you don't want to go standalone but yet you want to remove the MAF altogether, you could consider using the HKS F-CON V Pro. It allows you to remove the MAF physically.
454 whp, 1.7 bar boost, pump gas, water/meth. 501 whp, 2.2 bar boost, pump gas + avgas, no water/meth. www.viosturbo.com - World's first 500 WHP 1NZ-FE |
#2 | |
![]() ![]() Drives: Yaris Join Date: Apr 2009
I have the Greddy E-manage Ultimate and use the Greddy sensor pressure..I can eliminate the maf with this greddy ecu but I need the Maf value.. |
| Turbo Kit - trade for stock parts! | crankyelbow | Items for Sale by private party | 62 | 02-03-2009 12:30 PM |
| $2500 Turbo Kit is back to life! | bdc87 | Forced Induction Forum | 8 | 10-20-2008 09:46 AM |
| Under $2500 Turbo Kit w/Intercooler coming soon! | cdydjded | Forced Induction Forum | 58 | 09-23-2007 02:02 PM |
| ZPI to produce yaris turbo kit and exhaust | turboyaris | Forced Induction Forum | 15 | 06-09-2007 01:24 AM |
| ZPI to produce yaris turbo kit and exhaust | turboyaris | Forced Induction Forum | 30 | 04-04-2007 02:10 PM |
