Old 04-25-2009, 02:26 PM   #1
whooppee777
I used to have 1700 posts
whooppee777's Avatar
Drives: 2008 Yaris Hatch
Very interesting thread on scionlife
http://www.scionlife.com/forums/view...r=asc&&start=0
Old 04-25-2009, 02:38 PM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
yes, very interesting:
Alex, read the previous page. This twincharge project is DEAD for me. I've already sold the supercharger. I'm not concentrating on an all-turbo build.
HMMMMMM i wonder why he gave up?
because he realized it's not worth the time/money/weight ?
Old 04-25-2009, 02:48 PM   #3
whooppee777
Tamago is officially an
Did you not graduate from Grade School, because you don't read very well.
vettereddie's last post
"Yeah, the intake temp is what I saw was the biggest issue and why the twincharge varient is NOT happening. If a new manifold was done after the supercharger that had a air-to-water intercooler built in, then it could probably work. Alternately, I could have used meth injection, but on a daily driver that would be a pain to keep filled. "
and on page 3 he elaborates on his reason for not twin charging
"Simply put, the incoming pre-pressurized air would be at elevated temperature. The compressor rotor lobes are metal and do undergo thermal expansion. If the intake temp is too high, they will expand out of tolerance and hit instead of mesh, locking the compressor. Also, methanol can not be injected pre-s/c to cool the rotors because it could displace the oil in the sealed bearings and dry them out, damaging the compressor shaft. Elevated temperature could also de-laminate the anti-friction coating on the lobes, creating a FOD issue in the compressor, or worse, get pulled into the cylinder. "
it had nothing to do with whether it was "worth the time/money/weight"
congrats Tamago, you officially made an ass of yourself.
So... twin DIN install. (NOT Double DIN) Is it possible? WolfWings In Car Entertainment + Electronics (audio / video / alarm) 15 04-01-2009 08:49 AM
Twin engine Yaris. ddongbap Off-topic / Other Cars / Everything else Discussions 18 12-15-2008 10:54 PM
Twin Charge!!! (the best of both worlds) DollaZo Forced Induction Forum 51 11-15-2008 01:07 PM
JDM STABILIZER CHARGING SYSTEM ketel0ne Performance Modifications 15 09-13-2006 08:56 PM
