Old 04-27-2009, 01:47 AM   #1
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Originally Posted by Liu997 View Post
Wait the kit I used didn't have no red wire, do you mean the wires I connected under the steering wheel. I still don't know much about electrics cause this is my first DIY.
Are you trying to wire the foglights so that the foglight indicator on the instrument panel lights up, too? If you are, then disregard my posts in this thread.
If you're not, then don't connect anything that's under your steering wheel. You don't even have to remove the steering column plastics.
The kit you bought has different color wires from other kits that other people bought. So, in your case there is NO red wire. It's probably a different color. You have to find out which wire on the switch is the CONSTANT POWER and which wire is the ACC/SWITCHED POWER.
The two wires in the picture are coming directly from the harness that goes to your foglight switch.
Old 04-27-2009, 08:34 AM   #2
Liu997
Drives: 2008 Red Yaris LB
Yea I'm wiring so the the fog indicator comes on. What would I do then. Modify the switch?
Liu997 is offline   Reply With Quote
Old 04-27-2009, 04:25 PM   #3
Take a look at the end of this thread:
http://www.yarisworld.com/forums/sho...t=15941&page=3
I have been trying to help cyberfrogg with the same issue.
Part #s for Fog Light install? Can anyone who works for Toyota confirm? IsLNdbOi Cosmetic Modifications (Exterior/Interior) 73 12-23-2010 05:15 PM
test fit 06-07 Yaris 4 door fog light winson California 15 01-13-2009 08:25 PM
DIY:Day time running light Disabled with stock fog light remain function summergxz DIY / Maintenance / Service 12 09-26-2007 10:42 AM
Reverse light vs Rear Fog light cooldavidko General Yaris / Vitz Discussion 3 01-03-2007 03:09 AM
