Old 04-27-2009, 08:47 AM   #1
Frank Graham
Drives: 2007 Yaris
Guys, I gotta thank everyone who has piped up! You have given me courage to take on the oil change place and you have given me some advice (get a new engine from Toyota, instead of a rebuild) that I wouldn't have known about.
My pal (female) is utterly heartbroken about the thing: she is a single mom who drives her kids all over kingdom come every day and she is out a car for the duration of getting this fixed. Got to get a rental car that she can't afford for how ever long this takes.
She's got a valuable resource in, actually, me. I'm a lawyer and I'm hammering out what we call a "nuclear-war" letter to the lube joint in a few minutes. I expect them to come back with "not our fault" or "you can't prove it" or "ya wanna sue us? Get in line" response.
I used to do all my own car maintenance when I was in school and afterwards, so I identify with the DIY attitude. My pal, though, hasn't the time or ability to do this sort of thing.
Anybody have a WAG (wild-ass-guess) as to the cost of getting a new engine, assuming we have to do that without the assistance of the lube joint?
Frank Graham is offline   Reply With Quote
Old 04-27-2009, 08:57 AM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
www.car-part.com
look for an xA, xB, echo engine. you'll have to swap wiring harnesses though, and throttle bodies.
should be able to get a low miles longblock for under $500. if i was local to you i'd do the swap for $200 labor.
you should be able to get the entire job done for under $1000 if you research properly.
Old 04-27-2009, 10:33 AM   #3
WolfWings
WolfWings's Avatar
11101-21061 and 11400-21220 will run about $3200 combined, those are the bare-minimum body-shop-labor-intensive replacement options of new lower block, new head, but re-using everything down to the valve cover and oil pan but none of the guts as far as I can tell.
There's no price listed for the 'full engine assembly' part, 19000-21860, but likely around $4-$4.5k from Toyota.
DIY: CHANGE MANUAL TRANNY OIL ttufrosty DIY / Maintenance / Service 157 09-07-2018 01:43 PM
Oil drain plug gasket question schleppy DIY / Maintenance / Service 7 04-17-2009 05:35 AM
motor oil drain plug washer xpeteyjtx DIY / Maintenance / Service 13 12-30-2008 01:27 PM
Oil Drain Plug Size? Nigal DIY / Maintenance / Service 4 05-31-2007 01:55 PM
