don't.
take the sleeve out, and use the OEM mounting holes. do it. you'll see how the holes line up with the OEM bracket. You might be wondering, but if you use the OEM DIN mounts, you are not to use the plastic shroud that goes around the HU. which you probably would have to when using a metra kit. |
![]() ![]() Drives: Yaris 5 door Liftback Join Date: Oct 2008
I had a similar metal sleeve and it was a huge pain in the butt to find a way to securely mount it to the metra kit. Mine didn't even have half the tabs yours has in those pics. So only one side of the unit was fit snugly. I had to do some "custom" adjustments to the sleeve and kit to finally get it secure.
#3 | |
![]() ![]() ![]() Drives: Silver 2007 3Dr - Gryph Join Date: Jul 2007
![]() Last edited by WolfWings; 04-29-2009 at 05:36 PM. |
| Anyone custom a scangauge under their single din unit? | YarisSedan | In Car Entertainment + Electronics (audio / video / alarm) | 5 | 02-13-2009 11:49 AM |
| Is "full DIN" the same as single DIN? | whooppee777 | In Car Entertainment + Electronics (audio / video / alarm) | 1 | 06-22-2007 06:49 PM |
| Pic Request: Scangauge mounted in pocket under single din CD player? | nebulight | In Car Entertainment + Electronics (audio / video / alarm) | 1 | 04-29-2007 06:56 PM |
| Single DIN Digital Gauge Cluster | Galavoxx | Performance Modifications | 11 | 12-29-2006 03:09 PM |
| Trim/Dash Kit (for single DIN headunit) for Yaris yet? | bigsky2 | In Car Entertainment + Electronics (audio / video / alarm) | 46 | 09-01-2006 07:30 AM |
