My R1 eats my Vitz!!
Drives: '07 Vitz Lifty, Stick Shift Join Date: May 2007
Ok i see that now that I look at the pic. You had one more white one in with the brown one huh? And I see I was looking at the wrong side of the connector...duh. Anyway I'm gunna try that other pin in the ecm and try again tomorrow. Thanks a lot we'll see what happens :)
My Car Rules! Last edited by nickhjort; 05-03-2009 at 08:50 PM. |
#2 | |
I was just tracing the 7.5A IGN fuse and I think that the pin you are on, on the ECM, is hot, so when you hit the switch it grounded it and popped the fuse, as that fuse feeds parts of the ECM. By the way, before you road test with the correct pin, try the ON button in the driveway to be safe. I can hit the on with the ignition on and engine off and the cruise light comes on. Obviously you won't be able to tell if cruise is actually working, but at least you'll know if you pop a fuse. |
| DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag | CTScott | DIY / Maintenance / Service | 307 | 04-04-2023 03:43 AM |
| DIY Cruise Control on 07-08 Yaris (step by step) | Vince87 | DIY / Maintenance / Service | 431 | 12-28-2020 01:37 AM |
| Cruise Control - Again! | CB900F2 | DIY / Maintenance / Service | 47 | 06-17-2010 06:29 PM |
| Cruise control vs MPG | YarisOwnersDad | Fuel Economy Forum | 15 | 05-29-2009 03:55 PM |
| Using Cruise control | Driver | General Yaris / Vitz Discussion | 14 | 11-09-2006 10:12 PM |
