Old 05-04-2009, 12:25 AM   #1
The little red pill
Taking care of Bubbles
Drives: 2009 Yaris LB "Bubbles"
Also, changing the oil yourself gives you pride in your vehicle, and a sense of satisfaction in doing the job yourself. An oil change is the easiest maintenance item you can perform. I NEVER take my car somewhere to have the oil changed. I've had bad experiences with people putting too much oil in, not enough, spilling it all over the engine bay and then having my car smoke. Nope, just ME working on MY car thank you.
2009 Absolutely Red LB. "Bubbles"
The little red pill is offline   Reply With Quote
Old 05-04-2009, 12:36 AM   #2
Pitt Yaris
Drives: Flint Mica Sedan
One reason I change my own oil is because it's easy and I'm cheap. The second and just as important reason is garages overfilling/underfilling/etc. as you said.
Old 05-04-2009, 09:57 AM   #3
socko
Drives: 07' Liftback, man., Bayou Blue
And it's even easier if you remove the oil pan drain plug and put in a Fumoto oil drain valve (for about $20). Then, when you change oil, all you have to do to drain is to open the valve.
socko is offline   Reply With Quote
DIY: CHANGE MANUAL TRANNY OIL ttufrosty DIY / Maintenance / Service 157 09-07-2018 01:43 PM
Help with oil change specs autophile DIY / Maintenance / Service 31 04-25-2011 09:22 PM
Oil change time... yay! YarisFan007 DIY / Maintenance / Service 10 09-19-2007 05:40 AM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 08:16 PM
Oil change question Ryu DIY / Maintenance / Service 22 03-07-2006 11:21 PM
