Old 05-04-2009, 10:20 PM   #1
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
awesome! i plan on doing meth injection during my tune also! have fun with your extra HP!
Old 05-04-2009, 10:31 PM   #2
very nice....
best to buy washer fluid by the case
im curious to see the adapter plate for the throttle body
Old 05-05-2009, 02:52 AM   #3
808_Yaris
Where is Oahu?
808_Yaris's Avatar
Drives: 5-door meteorite metallic
amazing! can't wait to see the tests!
808_Yaris is offline   Reply With Quote
Old 05-05-2009, 05:37 AM   #4
Sabretooth
37HSSV
Sabretooth's Avatar
Drives: '11 Mazdaspeed 3
Just Wow...only the 2nd or 3rd Retrofitted Yaris to an Xa or Xb kit. Major congratz!
I was hoping sometime that someone would attempt a Greddy Xb S/C kit so we can see how that goes. Seeing it comes with Emanage blue, we could tune it similar to Chino's kit has been tuned. I know of one vid on Youtube of a Yaris with the Xb supercharger, although I dont know how it was done, or if its still running strong.
Old 05-05-2009, 06:43 AM   #5
Tamago
Tamago's Avatar
Drives: UZJ100
IMO, Blitz (lysholm) is a superior supercharger to Greddy (Eaton) as the Eaton unit is less efficient
Old 05-05-2009, 08:42 AM   #6
TheRealEnth
Beast
TheRealEnth's Avatar
Drives: 2007 Blz Blu LB
sick with it
Its a Chao!!!
Old 05-05-2009, 09:23 AM   #7
nsmitchell
nsmitchell's Avatar
Drives: LB-Auto-PWR-ABS-Cruise-Springs
Awesome! So the meth/water is used to cut out knocking so you can increase compression?
Other car is a 2005 Mustang Convertible 4.0L V6 Manual - Legend Lime
Get YarAss in gear!
RIP - Casey Tatum
nsmitchell is offline   Reply With Quote
Old 05-05-2009, 09:27 AM   #8
Morgan
Morgan's Avatar
Drives: 07 MM LB
the water/meth kit is from AEM, I ordered it from Summit for about $400 shipped and it comes with different size injectors (I just used the smallest one in the kit). The nozzle must be put BEFORE the TB but AFTER the maf. The AEM system is progressive and you can set what psi it will start and what psi you want full to be. The kit has a controller box mounted in the car for tuning and my only complaint is that the adjuster is quite obviously set up to handle like 30+lbs of pressure so adjusting it for the wee 6-8ish lbs has been interesting.
I have kept my original Yaris TB, so no cable its still DriveByWire. But the plate that mates the two together is basically a glorified gasket made from StarBoard (marine ABS plastic) with for a 2ftx3ftx3/4in was about $30. StarBoard may quite possibly be the coolest material to work with ever. It is rated for about 250*F so its safe for the temperature range I needed and you can drill into it and cut it with normal wood working tools. Basically my TB is upside down and one of the holes in the Yaris TB is matched up with a hole to the Blitz intake tube and then the rest of the holes are either counter sunk into the StarBoard or drilled through with a nut and bolt to hold them together. And of course rtv to make a nice seal.
I am supposed to be going out of town on Wed, might push it back til Thursday so I can have more time to get ready. I've already burned through 1/3 tank of fuel (93 octane, cause Florida is awesome!) and 1/4 water-meth mixture with flooring it and trying to tune it.
The water methanol is pretty easy to set up, the US has been doing it will all piston driven airplane engines since like WWII and its known to be pretty safe and reliable. Most people put a water injection setup on their cars to squeeze out more octane and get more out of the engine. Living in Florida with no intercooler, I'm using it to cool and reduce my chances of knock. The concentration depends on what you need. Water - to cool; Methanol - increase octane/reduce knock. I need both so I'm running pretty much a 50/50 mix by volume.
I really loved chemistry and never thought I'd EVER have to use it in the real world. BUT when you buy a 1 gallon washer fluid and its a 33% methanol concentration and you have 100ml of Heet (~$2 from any auto parts store) which is 99% methanol. Rough numbers find something to pour both fluids into and shake. After its all mixed together you have a 40% methanol by volume and for now a 40meth/60water mix is close enough. For summer I will probably need to bump it up to 50/50.
Look into the concentrations for your needs, I'm not using this setup for more power but when tuned correctly it will increase the octane and cool the engine... so voila more power
hope that may answer some questions? all in all I probably wont go through that much methanol (or gas lol) but its new and the first few tanks after stuff like this are always pretty crappy mileage, right
Old 05-09-2009, 12:23 PM   #9
supmet
Drives: 2007 4 Door Yaris
100 mL = 3.38 oz
33% of one gallon = 42.66 oz
42.66 + 3.38 = 46.05
46.05 oz /131.38 oz = 35%
Is my math wrong?
Old 05-05-2009, 06:43 PM   #10
Morgan
Morgan's Avatar
Drives: 07 MM LB
update - I noticed the belt slipping (and squeaking) while running the a/c and the supercharger, so I swapped back to the pulley that came with the kit and got a 66 inch belt [I was running a pulley from Advanced Auto Parts and a Gatorback 66.7in belt]
But after some fun in second gear, it pulls just as hard and runs great with 4 people and the a/c on
Old 05-09-2009, 10:07 AM   #11
how did I miss this? great job, more boosted ladies FTW
Old 05-09-2009, 05:29 PM   #12
ztrack157
Vroom Vroom Beep Beep
ztrack157's Avatar
Drives: Powered Roller Skate
Send a message via AIM to ztrack157 Send a message via MSN to ztrack157 Send a message via Yahoo to ztrack157
nope looks right. 35.04%
Ever blown out an R-200 diff god know's I have
ztrack157 is offline   Reply With Quote
Old 05-11-2009, 10:43 AM   #13
Russelt3hPirate
l33t3st Asshole
Russelt3hPirate's Avatar
Drives: MY07 Yaris Liftback
as long as her mixture is consistent and tuned on that same mix it doesn't really matter what the % is.
same goes with mixing fuels, if I ran 1/4 tank 93 and 5 gallon 110 for my tune anytime I run my "race map" I just need to have 1/4 or less of 93 and 5 gallon of 110 and I'm good. (note, example isn't from a Yaris, at least not yet anyway... ;) ).
Russelt3hPirate is offline   Reply With Quote
Old 05-14-2009, 11:31 AM   #14
Morgan
Morgan's Avatar
Drives: 07 MM LB
% by volume and % by weight are different... I can never remember which one is which but I know the math you provided is not the math I used to determine the concentration
Old 05-14-2009, 11:32 AM   #15
Tamago
Tamago's Avatar
Drives: UZJ100
% by volume and % by weight are totally different...
you geek ;)
welcome back!
Old 05-14-2009, 12:07 PM   #16
Tamago
Tamago's Avatar
Drives: UZJ100
methanol and water have different specific gravities, for sure.
Old 05-14-2009, 12:09 PM   #17
Russelt3hPirate
l33t3st Asshole
who cares!
use the same mixture everytime and stop doing math.
Old 05-14-2009, 12:10 PM   #18
Tamago
Tamago's Avatar
Drives: UZJ100
Originally Posted by Russelt3hPirate View Post
who cares!
that's hilarious coming from you sir
List of Boosted Yarisworld Members whooppee777 Forced Induction Forum 262 11-23-2022 05:49 AM
Belt Part #'s For Blitz Supercharger whooppee777 Forced Induction Forum 33 08-31-2017 11:46 AM
anyone with Blitz supercharger? yrsdrgn Performance Modifications 52 08-24-2010 07:57 AM
Blitz Supercharger vendors sdyaris Forced Induction Forum 32 09-18-2009 12:28 AM
blitz supercharger!!! djgab101 Australia 4 11-20-2008 05:06 AM
