Old 05-05-2009, 09:53 AM   #1
IllusionX
Drives: 07 Yaris Sedan Aero
I am no mechanics, but have you checked all the components? i mean.. air filter, spark plugs, o2 sensors, MAF?
What does it mean to run like a bag of spanners? Is it automatic or manual ?
Old 05-05-2009, 10:22 AM   #2
Yeti
Drives: 1999 Silver Yaris SR
Yes, I've checked all that - I AM a mechanic! It's had new plugs, air filter, cleaned the throttle body etc.
It's a manual - but even without driving it it runs lumpy, misfires and smokes (unburnt fuel) until it's warm.
I'm 100% sure it's the coolant temp sensor - I just don't know where to find it - there's 2 sensors down the flywheel side of the head - one has 3 wires and one has 2. Don't know which one it is - if I know, I can unplug it and use a variable resistor to mimic the temp sensor - and then order one from the dealer for it.
"Runs like a bag of spanners" means it's running like crap!
Yeti is offline   Reply With Quote
Help ASAP!!!! low coolant indicator MeggiemobileSFLA DIY / Maintenance / Service 29 08-03-2013 01:09 AM
Coolant Service N9QGS DIY / Maintenance / Service 31 11-27-2012 06:55 AM
Inlet air temp vs. vehicle speed LtNoogie Performance Modifications 8 04-27-2009 12:20 AM
outside temp on cluster??? ae92trueno7 Cosmetic Modifications (Exterior/Interior) 11 01-01-2009 10:36 PM
Engine Coolant Temperature djino General Yaris / Vitz Discussion 18 07-16-2007 12:26 AM
