Old 05-05-2009, 01:06 PM   #1
IllusionX
Drives: 07 Yaris Sedan Aero
if it's lumpy and misfires, have you checked the coil packs ?
It's hard to believe how a coolant temp sensor could affect the car to cause such troubles. Also, if you have the 1.3L or a 1.0L, it would be very hard for us to help, as we only have the 1.5L engine in our yarii.
Old 05-06-2009, 07:43 AM   #2
Yeti
Drives: 1999 Silver Yaris SR
It's a 1.3. I changed the coolant temp sensor this morning, and no difference. :-(
MAF maybe? The ECU warning light is on - anyone know where I can get software that will read the codes? I have an OBDII interface for the serial port on the PC, but no software.
Yeti is offline   Reply With Quote
Help ASAP!!!! low coolant indicator MeggiemobileSFLA DIY / Maintenance / Service 29 08-03-2013 01:09 AM
Coolant Service N9QGS DIY / Maintenance / Service 31 11-27-2012 06:55 AM
Inlet air temp vs. vehicle speed LtNoogie Performance Modifications 8 04-27-2009 12:20 AM
outside temp on cluster??? ae92trueno7 Cosmetic Modifications (Exterior/Interior) 11 01-01-2009 10:36 PM
Engine Coolant Temperature djino General Yaris / Vitz Discussion 18 07-16-2007 12:26 AM
