#163 |
SIPNDEW
and you cannot get the clamp to clamp tight just before the studs?
#164 | |
![]() ![]() ![]() ![]() Drives: 2009 Yaris Hatchback Join Date: Feb 2009
#165 |
I tried to use a hose clamp when I did the install the first time. It stayed on for bit, but once the engine got hot, the clamp popped right off. The neck of the TB isn't long enough to clear the studs & fit a hose clamp.
#166 |
![]() Drives: . Join Date: Apr 2009
thats why I use a bigger hose clamp
#167 |
#168 |
#169 |
#170 |
I guess ill just run in without the clamp and cross my fingers
#171 |
SIPNDEW
get 3 more bolts like the one lower left bolt and replace the 3 studs.
#172 |
Just finished the install and holy fucking oscillation
form 1000-3000 rpm from a cold start. I tried driving around a little bit and it started jumping up to 4k on idle and a CEL. How long does it typically take for the oscillation to start smoothing out? It's too late here (9:15) to mess around with it more. Don't want to piss off the neighbors. Any suggestions?
#173 |
It took about 2 days or so for the oscillation & CEL to finally go away
#174 |
I am doing to leave the battery disconnected overnight incase 2 hours wasnt enough.
#175 |
#176 |
I got oscillation at cold idle as well as intermittent CEL for the first two days, then both just went away completely. All I get now is the high (3,000 RPM) cold idle and better performance. I only did local driving during those first few days, no highway or any heavy pushing.
#177 | |
#178 |
WTF I just hooked the battery back up and started it up again and my idle was perfect with no oscillation
Hopefully it stays that way. I didn't want to even take it around the block because I have had about half a beer and their are mad cops out for cinco de mayo. Hopefully I will have a nice drive to work tomorrow
#179 |
Don't be surprised if the oscillation comes and goes for the first couple days. This happened to me and I thought everything was fine, then I got oscillation on the next cold start. Just be patient and give it a few days to work itself out.
#180 |
No clamp for months now on mine and no problems.
AEM CAI, NST Pulleys/SSK, WR 4-2-1 Header, TRD axelback, R1 Concept Rotors, TRD Sway Bar, Nitto Rear Strut Bar, Cusco GT-Zero Coilovers, 1ZZ-FE 1.8L TB |
| 1.8L Engine Swap, Possible? | Yaris T-Sport | Performance Modifications | 4 | 05-06-2007 06:57 PM |
| swap for 2zz-ge???? | yarisTOONR82 | Performance Modifications | 12 | 03-23-2007 07:15 PM |
