The check engine is probably throwing a misfire code on one of the cylinder.
I'm repeating myself, Have you check the coil packs?? You are a mechanics, you should be able to diagnose which cylinder is malfunctioning. try this for the PC ODBII reader. http://obddiagnostics.com/ProgWin.html |
#2 | |
![]() Drives: 1999 Silver Yaris SR Join Date: May 2009
| Help ASAP!!!! low coolant indicator | MeggiemobileSFLA | DIY / Maintenance / Service | 29 | 08-03-2013 01:09 AM |
| Coolant Service | N9QGS | DIY / Maintenance / Service | 31 | 11-27-2012 06:55 AM |
| Inlet air temp vs. vehicle speed | LtNoogie | Performance Modifications | 8 | 04-27-2009 12:20 AM |
| outside temp on cluster??? | ae92trueno7 | Cosmetic Modifications (Exterior/Interior) | 11 | 01-01-2009 10:36 PM |
| Engine Coolant Temperature | djino | General Yaris / Vitz Discussion | 18 | 07-16-2007 12:26 AM |
