Old 05-06-2009, 10:13 AM   #1
Yeti
Drives: 1999 Silver Yaris SR
Originally Posted by IllusionX View Post
The check engine is probably throwing a misfire code on one of the cylinder.
I'm repeating myself, Have you check the coil packs?? You are a mechanics, you should be able to diagnose which cylinder is malfunctioning.
try this for the PC ODBII reader.
http://obddiagnostics.com/ProgWin.html
Just checked with my mate there - he changed the plugs, but not the coil packs - trying to borrow another Yaris to swap the coil packs over - I'll bring the OBD cable in tommorrow and try that software you gave me the link to, thanks.
Yeti is offline   Reply With Quote
Help ASAP!!!! low coolant indicator MeggiemobileSFLA DIY / Maintenance / Service 29 08-03-2013 01:09 AM
Coolant Service N9QGS DIY / Maintenance / Service 31 11-27-2012 06:55 AM
Inlet air temp vs. vehicle speed LtNoogie Performance Modifications 8 04-27-2009 12:20 AM
outside temp on cluster??? ae92trueno7 Cosmetic Modifications (Exterior/Interior) 11 01-01-2009 10:36 PM
Engine Coolant Temperature djino General Yaris / Vitz Discussion 18 07-16-2007 12:26 AM
