Old 05-13-2009, 02:21 PM   #10
IsLNdbOi
IsLNdbOi's Avatar
Originally Posted by MGargano View Post
I had the same problem with the new dash trim and a Pioneer AVH-P4000DVD. My head unit has that non-removable trim piece around it as well. Just use a dremel tool/sand paper/file to trim the plastic dash trim until it fits. Took me about 30 minutes but finally I got it to snap into place and it looks awesome. Don't give up because it can be done with a little patience. The pieces you file/sand cannot be seen once the dash trim is in place, so don't worry about that.
Wait so what did you have to file? The parts of the HU I circled in red or the trim piece from Scott? If it was the trim piece from Scott, what part of it did you file?
In doing some searching, I see mention of it being common to have to trim to fit the FH-P8000BT. I couldn't find actual dimensions for that ring. Usually the installation manual has the detailed dimensions, but not for that Pioneer.
Scott, add me to the list (if you have one) for the next group buy. I'd like another one of these since I damaged the first one. The damages could be easily fixed by sanding and repainting, but I don't have the time or skills for that.
IsLNdbOi is offline
Dash destroyed in electrical fire. purpleminx General Yaris / Vitz Discussion 79 06-12-2009 03:53 PM
Double Din 180mm Trim Bezel esyres In Car Entertainment + Electronics (audio / video / alarm) 19 03-19-2009 09:01 PM
[Recovered] Group Buy for Australia #1 (Badges) harveyjai Australia 9 12-13-2008 03:59 PM
