Old 05-15-2009, 03:13 PM   #1
if you unplug the switch at the seatbelt latch, don't you get a flashing seatbelt sign or something like that?
Old 05-15-2009, 03:43 PM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
you're correct
so. if your dealer won't disable the drivers side warning for you (which is possible, per the toyota service manual)
you can do this:
put a 20Kohm resistor between pin 3 and 4 under the seat
seat belt chime disable? Lewis DIY / Maintenance / Service 19 05-25-2012 04:36 PM
Anyone find out how to turn off the seatbelt chime? overboost General Yaris / Vitz Discussion 54 11-22-2008 10:07 AM
what water temp does cooling fan turn on gonzo452001 General Yaris / Vitz Discussion 10 11-07-2006 05:50 AM
