Old 05-17-2009, 11:15 PM   #1
ruimond
Drives: Yaris YR
When i installed a new belt for my NST underdrive pulley, my mechanic said if it made any squeaks when starting up i would have to tighten my belt.
Im guessing the same would apply to the noise you may be hearing if its the belt. It is just slipping and getting abit loose, but once it warms up it grips better.
You could try tightening the belt first if you have much tightening left. You can see how much more you can tighten on the silver/grey leaver with the bolt just above all the pulleys. Otherwise as someone said early you should just replace the belt they are pretty cheap.
Old 05-19-2009, 12:13 AM   #2
Aothachos
Drives: 2008 Yaris Sedan
Send a message via AIM to Aothachos Send a message via Yahoo to Aothachos
no i never touch the throttle lol i just start it and thats it, i never touch it
Aothachos is offline   Reply With Quote
Noise from the drums.... Lafiro General Yaris / Vitz Discussion 18 05-22-2009 09:49 AM
Underdrive Pulley Belt ruimond Performance Modifications 11 02-14-2009 09:05 AM
The Accessory belt? N9QGS DIY / Maintenance / Service 4 02-12-2009 11:05 PM
Radio noise.. need help TinyGiant In Car Entertainment + Electronics (audio / video / alarm) 13 12-06-2008 04:21 PM
Best Grease to use on the belt? hasher22 DIY / Maintenance / Service 11 04-23-2007 02:20 AM
