![]() Drives: 2009 Toyota Yaris; 4 dr Sedan Join Date: May 2014
Pressure Wash Radiators
I can't believe NO one on this thread has told anyone that the FIRST thing a person needs to do IF the a/c isn't putting out 40º air at the center air output on the dashboard ……is to remove the bumper & pressure wash & scrub clean all the dirt & bugs that have accumulated on the radiators.
WITHOUT proper air flow across the radiator, no a/c is going to put out the cold air it is capable of putting out. My a/c at present is putting out 50º air, I've visually inspected the radiators & they are clogged with bug guts & dirt. I'm going to clean the radiators, something I can easily do & then re check the temperature output. IF that doesn't lower the air output to 40º, then & only then will I take it to a dealership & pay for them to fix the problem as I have neither the equipment nor inclination to start removing or replacing a/c parts/hoses. |
![]() ![]() ![]() ![]() Drives: Yaris Sedan 5MT Join Date: Oct 2008
Actually, I had this problem. I thought something was wrong with my fan. When I actually looked into the weird noise, I found a napkin had been sucked into the fan compartment.
I was very thankful for the "cheap(er)" fix.
| Cold air intake vs air intake | Liu997 | Performance Modifications | 15 | 11-05-2009 06:32 PM |
| Simota Carbon Charger Cold Air Intake | lilredrocket | Performance Modifications | 18 | 04-13-2009 04:16 AM |
| Intake Systems Decision Maker.. | Blenjar | Performance Modifications | 25 | 09-15-2007 11:07 PM |
