#1 | |
What?
For these reasons, cars like the Yaris are designed with fairly soft suspension that handles most road conditions "comfortably" and the car is designed to handle predictably and safely. Predictable and safe handling for the average idiot driver means understeer. Enter the rear swaybar. A rear swaybar's purpose is to increase rear roll stiffness. Increasing rear roll stiffness has a lot of effects, but the most obvious is a reduction in body roll and an improvement in steering response, which the "performance-minded" driver likes... but the general public might actually prefer the car to be less "twitchy" and prefer a little body roll that allows the suspension to lean in a turn instead of making THEM lean in a turn. Increasing rear roll stiffness also changes the handling bias of the car and makes it less prone to understeer, or more prone to oversteer. The stiffer the rear of the car is made, the more likely it is to oversteer in an emergency maneuver. Toyota doesn't want the liability of putting the average idiot in a car that could oversteer unexpectedly, so they design their cars to understeer predictably. Now, if Toyota wanted the rear roll stiffness to be greater on the Yaris... they wouldn't have fit a swaybar to it, anyway. It adds weight, complexity and expense, things that are considered greatly in the design of such a car. Even if they used the TRD/Ultra Racing design (a beam axle reinforcement rather than a true anti-sway bar), it would still add at least 7 parts to the car, one of them being a bar that requires complex forming and welding and heat-treating, the others being a pair of bolts, nuts and washers. (if they put a REAL swaybar on the car, the part count would be at least 3 times as many with brackets, end links, bushings, etc.) No, if Toyota wanted to add more stiffness to the back of the Yaris, they would simply have designed a stiffer beam axle assembly that allowed less twist or they would have fitted stiffer rear springs... either of which would create a compromise to the level of comfort that the car was designed for. Um... what was the question again? |
![]() Drives: 2009 Yaris w/man.trans. Join Date: May 2009
Rear Sway Bar
Thanks for your thorough and thoughtful response. You're right, most people want that couch they can drive to work so Toyota would not be so compelled; and, thinking about it you're correct - there would be other engineered approaches a manufacturer would take.
And, do you have a rear sway bar and would you hesitate in recommending one for whatever reason? Again, thanks-- |
| DIY - rear sway bar [pics] | cali yaris | DIY / Maintenance / Service | 199 | 07-28-2022 05:25 AM |
| Rim Weights | bosbik | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 16 | 11-14-2009 06:42 PM |
| Possible Group Buy.. Racing Seats, Intakes? | TinyGiant | Items for Sale by private party | 60 | 09-11-2009 02:40 PM |
| Ultra Racing 23mm Rear Stabilizer Bar | Loren | Performance Modifications | 62 | 05-18-2009 07:20 PM |
| 12/20/08 Buddy Club USA 5th Anniversary Clearance SALE | DuckinOut | California | 3 | 12-18-2008 12:25 AM |
