Old 05-18-2009, 07:50 PM   #1
cdydjded
Drives: Yaris LB Turbo
Originally Posted by Russelt3hPirate View Post
why intercool it?
might as well make things easier and not intercool.
it'd be a lot cheaper too.
Safer, makes more power, less likely for detination, easier is not better, what is cheap now will cost you more later
cdydjded is offline   Reply With Quote
Old 05-18-2009, 07:57 PM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
6psi, intercooler is a waste.
run meth injection instead.
Old 05-18-2009, 08:39 PM   #3
cdydjded
A front mount does not need to be refilled, I think the waste would be refilling that little bottle every other day. Your comment makes no sense , why would a cooler, denser air charge be a a waste? Please think before you answer, I do not generalities........
Old 05-18-2009, 08:41 PM   #4
Tamago
Tamago's Avatar
Drives: UZJ100
let's see..
small engine
small turbo
15 feet of intercooler piping
1 psi drop thru cooler..
just to be able to say you have a front mount?
i'm not anti-intercooler, i just think front mounts are retarded in low boost applications. even the supra TT came with simple side mount intercoolers FROM THE FACTORY.
and since when does one burn through 2 gallons of water/meth every other day? you don't know anything about meth injection do you?
oh and i find it funny you say you RAN a speed shop in miami. what happened? RAN? why not RUNNING?
Old 05-18-2009, 08:38 PM   #5
Tamago
Tamago's Avatar
Drives: UZJ100
=what is cheap now will cost you more later
you mean something along the lines of running half an FIC and unplugging the stock o2 sensor?
Old 05-18-2009, 08:44 PM   #6
cdydjded
Listen, based on your smart ass remark I can tell you never used a FIC & have a reading comprehension problem. The FIC has 4 programable maps. Fuel, Ignition, O2 & MAF. AEM recomends to use the least amount of maps. Right now I have control of Fuel & Timing. Im not running a turbo yet so there is no need to clamp the MAF or manipulate the O20 signal. So basically its installed & works. Also I did not unplug the stock O2 sensor, I unplug the connection from the FIC to the O2.
Old 05-18-2009, 08:52 PM   #7
Tamago
Tamago's Avatar
Drives: UZJ100
1. i have an FIC mounted and wired by me in my car.
2. iirc you already burned up your stock o2 sensor..
bad wiring?
Old 05-18-2009, 09:00 PM   #8
cdydjded
bad wiring?
Congratulation on havin a FIC, based on what facts do you claim I burned my O2?
Old 05-18-2009, 09:04 PM   #9
Tamago
Tamago's Avatar
Drives: UZJ100
I disconnected the connection to the O2 & still have a CEL, I might have screwed up the O2
and what happened to you being SO SURE that i know nothing about the FIC?
Chino's Turbo Thread ChinoCharles Forced Induction Forum 299 03-17-2017 08:01 AM
GI: Turbo Manifold ChinoCharles Forced Induction Forum 4 04-13-2009 01:42 AM
xa/xb Turbo manifold for Custom set up CASTREX Forced Induction Forum 1 01-21-2009 02:43 PM
Why industries turbo manifold? anonymous user Forced Induction Forum 33 12-07-2008 01:11 PM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 02:26 PM
