#1 | |
![]() ![]() ![]() Drives: 2008 Yaris LB Join Date: Apr 2009
Take this into consideration. I've driven from Los Angeles to northern California (300+ miles) non stop a couple of times already without the A/C on and had no problems with the engine overheating. The overheating light only comes on when I'm using the A/C. I'm a little hesitant about disconnecting hoses and taking parts out but I'll have a look and try and see what you're talking about. |
#2 | |
![]() ![]() Drives: Red Yaris Join Date: May 2009
-Phil |
#3 | |
I've driven on the freeway before with the A/C on in hot weather for 30+ minutes and the overheating light has never come on. It's only come on while driving on the streets. So what does the water temperature gauge look like and where can I get one? Where exactly do I install it? Is there a way to tell myself if the water pump is faulty or will a mechanic have to diagnose it for me? |
#4 | |
Your car does not overheat when it's in motion, because there is enough air that goes through the radiator to keep the engine cooled to safe temperature. As many stated, it might be the fan,the thermostat or the waterpump. Thought, if it was the waterpump, you'd overheat even in motion (ie, highway). So it could really only be the fan or the thermostat. I suggest you taking your car to the dealer instead of trying to fix it youself. |
| Cold air intake vs air intake | Liu997 | Performance Modifications | 15 | 11-05-2009 05:32 PM |
| Simota Carbon Charger Cold Air Intake | lilredrocket | Performance Modifications | 18 | 04-13-2009 03:16 AM |
