#1 | |
![]() ![]() Drives: Red Yaris Join Date: May 2009
-Phil |
#2 | |
![]() ![]() ![]() Drives: 2008 Yaris LB Join Date: Apr 2009
I've driven on the freeway before with the A/C on in hot weather for 30+ minutes and the overheating light has never come on. It's only come on while driving on the streets. So what does the water temperature gauge look like and where can I get one? Where exactly do I install it? Is there a way to tell myself if the water pump is faulty or will a mechanic have to diagnose it for me? |
#3 | |
Your car does not overheat when it's in motion, because there is enough air that goes through the radiator to keep the engine cooled to safe temperature. As many stated, it might be the fan,the thermostat or the waterpump. Thought, if it was the waterpump, you'd overheat even in motion (ie, highway). So it could really only be the fan or the thermostat. I suggest you taking your car to the dealer instead of trying to fix it youself. |
| Cold air intake vs air intake | Liu997 | Performance Modifications | 15 | 11-05-2009 05:32 PM |
| Simota Carbon Charger Cold Air Intake | lilredrocket | Performance Modifications | 18 | 04-13-2009 03:16 AM |
| Intake Systems Decision Maker.. | Blenjar | Performance Modifications | 25 | 09-15-2007 10:07 PM |
