Old 05-20-2009, 03:16 PM   #1
33OH
Drives: '08 Yaris
Yeah I know, it's just what popped in my head when I saw it.
Those wheels are an awesome price for what they are, I just love the Rewind styling.
I'll get the +20 offset though now, thanks a ton.
I still want a 195/50/15 though.
Old 05-20-2009, 03:26 PM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
you WILL have to add camber if you want to run a +20, so go ahead and order those camber bolts.
if you have access to a bench grinder, you can modify a set of washers rather easily. just make sure to buy stainless.
if you end up going +40 rewinds, remember, hub spacers are available! ;)
Old 05-20-2009, 03:50 PM   #3
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
IF the reason you are changing wheels is because of your Long comute you should also consider that the 195/50 tires will change a bit the OE gearing ratio. You will be cruising at higher revs than you normally do and fuel economy might got hurt.
That is IF Fuel economy over your comute is a concern... If not you might actually enjoy the shorter ratio....
Old 05-20-2009, 04:29 PM   #4
Tamago
Tamago's Avatar
Drives: UZJ100
4.5% increase in rev's @ any given actual speed (not indicated, of course)
Old 05-20-2009, 04:32 PM   #5
33OH
Drives: '08 Yaris
Ahh, good thinking.
Yes, I am concerned about fuel economy.
And thanks again Tamago.
Tire rotation: Does TPMS recognize tire position? jcdrotos Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 03-17-2011 02:00 PM
Why does Tirerack reccomend 185/50R15s for seeminlgy ALL of their 15" rims? St_G Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 03-16-2011 06:29 AM
Higher Tire Pressure captainm27 General Yaris / Vitz Discussion 46 01-27-2009 10:17 AM
Tire diameter list grampi Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 06-04-2007 04:03 AM
