Old 05-20-2009, 04:50 PM   #24
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
IF the reason you are changing wheels is because of your Long comute you should also consider that the 195/50 tires will change a bit the OE gearing ratio. You will be cruising at higher revs than you normally do and fuel economy might got hurt.
That is IF Fuel economy over your comute is a concern... If not you might actually enjoy the shorter ratio....
Tire rotation: Does TPMS recognize tire position? jcdrotos Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 03-17-2011 03:00 PM
Why does Tirerack reccomend 185/50R15s for seeminlgy ALL of their 15" rims? St_G Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 03-16-2011 07:29 AM
Higher Tire Pressure captainm27 General Yaris / Vitz Discussion 46 01-27-2009 11:17 AM
Tire diameter list grampi Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 06-04-2007 05:03 AM
The Tire inflation debate... Tankota General Yaris / Vitz Discussion 20 06-01-2006 08:09 PM
