Old 05-21-2009, 10:33 AM   #1
YarisSedan
Drives: 08 Yaris Sedan
Hmm understeer can be kinda fun sometimes but then very scarry and unpredictable at other times. The kind of your heart drops to your stomach id personally rather have oversteer that is easier for me atleast to correct.
Old 05-21-2009, 12:15 PM   #2
fuji
fuji's Avatar
Drives: Polar White Yaris HB
Does anyone know how thick the stock sway bar is?
fuji is offline   Reply With Quote
Old 05-21-2009, 12:27 PM   #3
ka0sx
ka0sx's Avatar
Drives: bone f*ing stock
*shrug* go outside with a micrometer?
ka0sx is offline   Reply With Quote
Old 05-22-2009, 11:18 AM   #4
MUSKOKA800
MUSKOKA800's Avatar
I have to think that the material a manufacturer chooses has as much effect on the performance of an anti-swaybar as its diameter. Other factors could also come into play (shape, arm length/leverage factor, etc)
So, one manufacturers 24mm bar may offer the same qualities of anothers 22mm product.
Trail and error may be necessary when mixing brands.
Old 05-22-2009, 11:38 AM   #5
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
While the idea here makes sense, it's not true. Swaybars are all made from steel, and the different types and grades of steel are of such little significance to the equation that they aren't even considered by engineers. The stiffness of the steel is a "constant" in the equation.
Unless you're building swaybars out of aluminum (dumb idea, aluminum doesn't make a good spring) or titanium ($$$$) or carbon fiber ($$$$$), swaybars of the same basic shape can be compared based primarily on their diameter.
Three things, really:
1. Diameter
2. Hollow or not (same diameter, but hollow = slightly less rate)
3. Length of lever arms.
Old 05-21-2009, 03:16 PM   #6
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
You most got it backwards....
Nothing fun about understeer.... and is more predictable and easier to control to the average driver... Natural reaction for most of the people would be to release the gas and touch the brakes making the front tires grip again.
Oversteer in the other hand can be fun for a driver who know what it is doing...
Ultra Racing 23mm Rear Stabilizer Bar Loren Performance Modifications 62 05-18-2009 07:20 PM
