Old 05-22-2009, 02:22 PM   #1
IllusionX
Drives: 07 Yaris Sedan Aero
UHHHH..... digging old thread up...
I'm not sure if i did it right, i took ~1 3/4 Quart out only??
Yet, filling it with 2QT did not over fill it. Or i now i have too much oil in there??
Old 09-13-2009, 05:57 PM   #2
andaconda
andaconda's Avatar
Drives: '09 Yaris Sedan
Originally Posted by IllusionX View Post
UHHHH..... digging old thread up...same go's here!
Going to change to "Amsoil Synthetic Manual Transmission and Transaxle Gear Lube 75W-90 API GL-4 (MTG)" after 7000 miles on the odometer. I have ground way too many gears from lack of pressing the clutch in all the way. I will feel better about getting the original gear lube out of the tranny.
I don't have a 24mm socket but the 15/16 I have fits well. The conversion is 24mm = 15.118/16 inch. Should I use my 15/16, or go buy a 24mm?
andaconda is offline   Reply With Quote
Old 09-13-2009, 06:21 PM   #3
Lazerdot
Lazerdot's Avatar
Drives: Blazing Blue 08 liftback
I bet a good 24mm socket would be worth having. All my tools are with my Karts, leaving me with standard tools(and few of um), really like having metric around.
Doin the same with my car soon..., only 14k on it though. AX might be beating it up some though. Sooner the better I guess.
One Year One Oil-AMSOIL at www.Trulube.com TRD Exhaust, Springs and Struts. TRD SSK. NST Underdrive Crank Pulley. Amsoil Dominator 10w-30 Racing Oil, Amsoil DOT4 brake fluid, Amsoil Severe Gear 75w-90 transmission oil, Ultra Racing 23mm Sway Bar, Camber Bolts, R1 Drilled Slotted front Brakes and SS Brake cables from Micro-Image. Orange Konig Daylight 17s, Kumo MXs. Greg@TruLube.com
Lazerdot is offline   Reply With Quote
Old 09-20-2009, 03:18 PM   #4
MUSKOKA800
MUSKOKA800's Avatar
I used a 15/16" (6 point impact type) socket today when changing over to synthetic. It fit just fine.
Old 10-17-2009, 11:15 AM   #5
andaconda
andaconda's Avatar
Followup:
I did the change to Amsoil.
A couple of tips tho:
I jacked up the drivers side of the car so that I could get to both plugs easier - but while I was draining, I let the car down off the jack, and then jacked it back up again to finish the job.
I did use my 15/16 socket with no problem.
Have the pan ready - I mean really ready - when I pulled out the filler plug, it came gushing out and missed my pan by a mile -- like all over the frame members, all over the jack, all over the driveway -- So be ready for it!
Have a helper on top with the fill funnel while you hold the fill tube in the fill hole -- you don't want to waste a precious drop of this expensive gear lube.
Don't over tighten the plugs. They're not that tight - 29 foot pounds.
Now I can't honestly tell any difference, but the cold weather hasn't come yet and I don't have but a couple of miles on it.
But at least I know it is changed out and I feel better about it.
My kid has been ribbing me about this switch from dino to synthetic. He said "you'll do anything to squeek one more mile per gallon, won't you!"
Help with oil change specs autophile DIY / Maintenance / Service 31 04-25-2011 10:22 PM
Yaris Auto need help with tranny oil change chrisada_to2a General Yaris / Vitz Discussion 2 05-17-2007 02:51 PM
DIY Oil Change Bassmonkey DIY / Maintenance / Service 42 02-19-2007 09:37 PM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 09:16 PM
Oil change question Ryu DIY / Maintenance / Service 22 03-08-2006 12:21 AM
