JDM yO!
Drives: '09 3dr. 5-spd Join Date: Oct 2008
Looking good! It looks like your passenger side is tucked in a few mm more than the driver side though.. my Yaris is the same..
#2 | |
What do you mean? where did you see that? D. .
. CLA 250, 4MATIC |
JDM Fred
I just installed these on my car and they look amazing! I'll take pics when the car is back on the lift. Just remember to be careful while doint the install, you don't want to screw the threads up like me
1990 Mazda Miata... I miss my Yaris
I just put my new wheels and I have rubbing issues in the back, I tried to uninstall the spacer but it was impossible. )o: any tips would be appreciated.
Thanks.
. CLA 250, 4MATIC |
#5 | |
Just a Herbicidal maniac.
Drives: 2008 Yaris S Sedan Flint Mica Join Date: Oct 2008
Anyway, will some kind of "puller" work? (Someone else mentioned a steering wheel puller, but I believe that was used to remove the brake drum.) Along with some heat and PB Blaster? I'm sure that bit of rust is holding it on... Even if you can't work on it today, getting some PB Blaster sprayed in there now would give it a couple of days or more to work it's magic. Then you can try again on the weekend.
2008 Toyota Yaris (Vios) 'S' sedan, Flint Mica, dropped on TRD springs, TRD anti-sway bar. Tinted rear windows. Lenso Samurai SC02 hyper black 17" x 7" rims, wrapped in 205x40x17 Federal ss595's. Color matched eyelids. Vios badge. Body color trunk trim (was chrome). Lamin-X tint on rear tails. Custom center exit exhaust. Tanabe front strut tower brace. |
Mr. 155 and climbing
Might be a stupid question, but if someone installs the Rear Disc Brake Conversion Kit the spacers would be a moot point correct?
#7 | |
l33t3st Asshole
Drives: MY07 Yaris Liftback Join Date: Nov 2006
I know a guy out in Europe installed a set of the PG spacers on his Vitz RS which had rear disc brakes. :) |
toyota
im curious if someone tried adding washer on the bottom..to make the tire tilt by a little angle..
l33t3st Asshole
The Penguin Garage Camber Shims did exactly that. :)
toyota
i have spacers that i've manufactured for another car. for disc brakes. i won't provide bolts though.
toyota
I'm curious what the 10mm Allen key is used for?
toyota
Forget it I found it
toyota
just to add on to this..for hatchback left rear is about 4mm pushed in vs the right.. i did an install on pg spacer left rear 13mm and right is 10mm and i got it pretty close to match..yaris frame is crooked by about 4mm rear left.
toyota
this thing wont work for 205/50/16 +40 offset. i did 13mm on left and 10mm on the right (due to left goes in more than the right..)got it flush on both side but still rubbing on the right shaved the fender worked well but with soneone on the back still getting rubadubdub on dips..i should have placed the shim .damn it! but now i dont want to do it if its not gonna fix the issue..1degree ?? would that move the upper tires in by what 2mm or less..
update... left rear for hatch is 5mm off vs right rear.. get 13mm n 8mm or 15mm n 10mm Last edited by marcus; 06-28-2010 at 12:13 PM. |
I installed a camber kit, thanks to Garm and other yariswold members for your suggestions trying to avoid rubbing. The installation is very easy if you have done the spacers, I added -1.5 degrees and Looks and Feels AWESOME!!! it does help with the rubbing issue but I still need to drive with more weight and find out. D. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 Yaris Join Date: Oct 2008
My right side is out further than the left, actually.
I know what you feel, you are not alone...
It bothers me a little bit, but If I don't tell.. nobody notice the discrepancy. ![]() D.
. CLA 250, 4MATIC |
| Penguin Garage Rear Hub Spacers!! | Penguin Garage | Sponsors Classifieds Area | 92 | 09-02-2009 06:16 PM |
| Gauging interest on hub spacers for the yaris | Tamago | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 61 | 05-22-2009 02:18 PM |
| Rear Spacers... (Who sells them?) | Saggio | General Yaris / Vitz Discussion | 6 | 02-06-2009 08:40 AM |
| Installing a rear window defroster | trn9 | DIY / Maintenance / Service | 0 | 01-06-2009 02:56 AM |
