Old 08-03-2010, 09:42 AM   #1
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
im running 16x7 +40 offset and just added 5mm spacer on the left rear.. looks alot more even compare to stock crooked frame..
Old 08-03-2010, 09:48 AM   #2
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
Where did you get the 5mm spacer?
D.
Old 08-03-2010, 10:05 AM   #3
DeathBeard
DeathBeard's Avatar
Drives: 2010 Yaris S
any local tire shop should carry a 5mm spacer
DeathBeard is offline   Reply With Quote
Old 08-03-2010, 10:06 AM   #4
marcus
toyota
marcus's Avatar
or any tire and rim place..cost me $10 bucks..i actually had 13mm for left and 10 mm for right spacer fr penguin but rubbing on me due to my offset..but itll work perfect for 45mm offset..
Old 05-21-2011, 10:53 AM   #5
SKurj
Drives: 09 Yaris 3dr HB, BRZ
This is perhaps the kit penguin should sell. Just fitted the 10mm on mine and was surprised how obvious the difference between the left and the right is. Well at least to me. 13-15mm for left, 10mm for right.
SKurj is offline   Reply With Quote
Old 05-21-2011, 12:02 PM   #6
marcus
toyota
marcus's Avatar
you should have just bought mine aint putting it back on my wheel offset on +40 is rubbing on dips..but it does look sick from the back though..
Old 09-08-2010, 01:37 PM   #7
derickveliz2
Finally I was able to pull out the spacers, when I was going to put back the camber kit I noticed that didn't fit and I had to trim the inner circle of the camber kit to make it fit, I wonder if this discrepancy had to do with the fact that the spacers where stuck!
Thoughts?
Old 09-11-2010, 06:12 PM   #8
Tamago
Tamago's Avatar
Drives: UZJ100
did you grease them before install?
Old 09-11-2010, 11:15 PM   #9
derickveliz2
Yes I did, and I noticed that they didn't fit loose but very tight and put extra grease, the lugs slowly set the spacers in place by pressure putting everything back together.
D.
Old 09-12-2010, 01:37 AM   #10
Tamago
Tamago's Avatar
Drives: UZJ100
D.
the lug nuts pulled the spacers on tight?
did you remove any of the rust buildup on the hub itself before installing the spacer?
Old 09-14-2010, 11:39 PM   #11
derickveliz2
Yes I did!
I was surprised that even the camber kit didn't fit and I had to trim it.
D.
CLA 250, 4MATIC
Old 05-21-2011, 12:29 PM   #12
pennyracer
boydstir
pennyracer's Avatar
Drives: 08 yaris liftback
Send a message via AIM to pennyracer Send a message via Yahoo to pennyracer
sorry to jump in but am i reading that the off set on the back of the lb yaris is different from the left to the right im running 17x7 momo wheels off set is 35mm i think but i want spacers ? looking for the straight facts that is just a picture of the front rim
[IMG][/IMG]
pennyracer is offline   Reply With Quote
Penguin Garage Rear Hub Spacers!! Penguin Garage Sponsors Classifieds Area 92 09-02-2009 06:16 PM
Gauging interest on hub spacers for the yaris Tamago Wheels, Tires and Suspension Forum sponsored by The Tire Rack 61 05-22-2009 02:18 PM
Rear Spacers... (Who sells them?) Saggio General Yaris / Vitz Discussion 6 02-06-2009 08:40 AM
Installing a rear window defroster trn9 DIY / Maintenance / Service 0 01-06-2009 02:56 AM
