Old 05-26-2009, 11:17 PM   #1
kurokoma-kun
Drives: 2007 Yaris HB
Originally Posted by Loren View Post
Look in your owners manual. It will tell you what spec you need, just like it tells you what spec of engine oil (but not what specific brand!) to use.
My owners manual says DOT 3.
I get what you're saying, that it doesn't matter under ordinary driving conditions, just for the record.
Old 05-27-2009, 10:35 AM   #2
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
On today's market, I think you'd be hard-pressed to find a "DOT 3" product that did not also meet the "DOT 4" spec.
Here's just one example: Castrol LMA
The main difference between the two specs is temperature. DOT 3 is good to a minimum of 401 degrees, DOT 4 to 446 degrees. So, Toyota specing the system for DOT 3 means that they don't expect the fluid to exceed 400 degrees in even extreme normal use. ("extreme normal use" typically means something like one good hard full stop from a fast highway speed, btw... most normal drivers will never do that more than once in succession, and that's all the factory braking system is designed to handle)
DIY (sorta) - RunStop Rear disc brake conversion eTiMaGo DIY / Maintenance / Service 17 07-02-2019 08:24 AM
DIY Rear Drum Brake Adjustment/Parking Brake W/ PICS Inside YarisSedan DIY / Maintenance / Service 73 03-11-2017 06:05 PM
BIG(GER)TM BRAKE KIT Vanderkitten Performance Modifications 23 01-04-2009 07:16 PM
Brake fluid info... 06vitzRS DIY / Maintenance / Service 5 12-26-2008 12:05 AM
Engine dress up - brake fluid resivoire cap? YarisSedan Cosmetic Modifications (Exterior/Interior) 5 11-15-2008 07:59 AM
