There was a thread on this a while back. Around 1800-2000rpm, the engine/car shake and you can even hear it.
There is no response from toyota as to what causes this. I have noticed that in 2nd gear, around 1800-2000rpm, my car is loud, and the engine sounds very bad. As soon as I give it more gas, and it gets above 2000rpm, or changes gears, the noise is gone, and it sounds/feels smooth again. I really don't know whats causing this. I have 50,000miles on the car so far. This coming week I am going to change my motor oil(royal purple with 6000miles on it), and transmission fluid. I am going to also replace the spark plugs, and maybe even the cables if need be. At the end I will also be replacing the drum shoes, and the shocks. Honestly I say all that but at the same time have $0 to do it all. *sighs* |
#2 | |
![]() ![]() ![]() ![]() Drives: 08 3DR 5M Bayou Blue; 09 Fos Join Date: Oct 2008
#3 | |
Drives: 2007 Yaris Hatchback Join Date: Oct 2008
Taking care of Bubbles
Drives: 2009 Yaris LB "Bubbles" Join Date: Apr 2009
Sounds like a good idea to just have it checked out. Since it's not a maintenance item, any work should be covered under warranty. Even if not, they are legally bound to provide you with a written estimate before any work is done.
2009 Absolutely Red LB. "Bubbles" |
#5 | |
SIPNDEW
#6 | |
![]() ![]() ![]() Drives: '08 5-door Join Date: Apr 2009
| DIY: Intake Installation | redyaris | DIY / Maintenance / Service | 53 | 08-23-2014 05:34 AM |
| The last gas question | Tonavi | DIY / Maintenance / Service | 56 | 04-27-2009 08:40 PM |
| How would you sound deaden engine compartment? | Yawesh | General Yaris / Vitz Discussion | 11 | 01-11-2009 03:41 PM |
| The Advantages of Nitrous on an Engine | KCALB SIRAY | Performance Modifications | 7 | 01-02-2009 10:53 AM |
| weird sound | yrsdrgn | Cosmetic Modifications (Exterior/Interior) | 7 | 02-05-2007 11:47 PM |
