Old 05-28-2009, 09:32 AM   #13
TheSilkySmooth
TheSilkySmooth's Avatar
Drives: 08 3DR 5M Bayou Blue; 09 Fos
Originally Posted by Lafiro View Post
I have 50,000miles on the car so far. This coming week I am going to change my motor oil(royal purple with 6000miles on it), and transmission fluid. I am going to also replace the spark plugs, and maybe even the cables if need be. At the end I will also be replacing the drum shoes, and the shocks.
Honestly I say all that but at the same time have $0 to do it all. *sighs*
The stock oil filters are defective - use a wix 51396 or a Purolator. The RP oil doesnt work well in this car. Just run Mobil clean 5000 or 7500 or Penzoil Platinum 5w-30. if you have the bucks run Motul 8100 . You use the wrong stuff the vvti oiling gets messed up and the car runs bad. I Cannot overemphasize how important it is NOT to use the black toyota denso filters for tthe car to run correctly.
TheSilkySmooth is offline   Reply With Quote
DIY: Intake Installation redyaris DIY / Maintenance / Service 53 08-23-2014 05:34 AM
The last gas question Tonavi DIY / Maintenance / Service 56 04-27-2009 08:40 PM
How would you sound deaden engine compartment? Yawesh General Yaris / Vitz Discussion 11 01-11-2009 03:41 PM
The Advantages of Nitrous on an Engine KCALB SIRAY Performance Modifications 7 01-02-2009 10:53 AM
weird sound yrsdrgn Cosmetic Modifications (Exterior/Interior) 7 02-05-2007 11:47 PM
