Old 05-27-2009, 10:55 PM   #1
Originally Posted by ezhacker1 View Post
Iv searched and searched on the forums here, best "nipple" i see that is easy to get to is the one above ecu on passenger side but i want to have my power wire as short as possible to amp, so either going pass the drivers side which i still cant find a nipple to get through or under the car. Any helps?
There's a huge bushing on the drivers side where a large harness goes through:
Old 10-22-2011, 08:33 PM   #2
othater
Drives: 07SedanS06Taco
Firewall
I know this is a old post but I'm sure someone might be looking for a location in the firewall like I did.
This is the bushing I used, Thanks CTScott, worked perfect.
I used a fiberglass rodder and pushed it through slowly on the outer portion of the bushing,
tied on the power cable, wiped some car wash soap on it and it slid right in.
othater is offline   Reply With Quote
Old 10-22-2011, 08:44 PM   #3
TOLMACH
Drives: soarer
Thanks, very useful
(another solution)
I had similar problem some time ago and used @the hole@ proposed by 3cylTurbo (who recently posted his HB audio install here) - hole right above the ECU (square electronic block) on the passenger side - which also worked in my case I ran my wire to the amp under the passenger seat (in which case the hole on the passenger side worked out very well)
radio wire colors & alarm wire color reference guide battleversiontc In Car Entertainment + Electronics (audio / video / alarm) 43 06-06-2023 02:12 PM
Electrical System Upgrade Advice sqcomp In Car Entertainment + Electronics (audio / video / alarm) 6 03-23-2016 01:15 AM
Running Firewall Power Wires for subwoofer MacMaster761 In Car Entertainment + Electronics (audio / video / alarm) 17 03-06-2010 03:04 PM
Power wire gauge vs stereo wattage goku87 In Car Entertainment + Electronics (audio / video / alarm) 1 02-24-2009 02:16 PM
Harman Kardon Drive + Play for IPOD sroberts In Car Entertainment + Electronics (audio / video / alarm) 5 07-01-2006 01:05 PM
