Old 05-28-2009, 09:32 AM   #1
TheSilkySmooth
TheSilkySmooth's Avatar
Originally Posted by Lafiro View Post
I have 50,000miles on the car so far. This coming week I am going to change my motor oil(royal purple with 6000miles on it), and transmission fluid. I am going to also replace the spark plugs, and maybe even the cables if need be. At the end I will also be replacing the drum shoes, and the shocks.
Honestly I say all that but at the same time have $0 to do it all. *sighs*
The stock oil filters are defective - use a wix 51396 or a Purolator. The RP oil doesnt work well in this car. Just run Mobil clean 5000 or 7500 or Penzoil Platinum 5w-30. if you have the bucks run Motul 8100 . You use the wrong stuff the vvti oiling gets messed up and the car runs bad. I Cannot overemphasize how important it is NOT to use the black toyota denso filters for tthe car to run correctly.
Old 05-28-2009, 11:54 PM   #2
SilverGlow
Drives: 2007 Yaris Hatchback
And I cannot overemphasize how wrong you are about Toyota filters. They are more then fine, Granpa, or whatever your other user id is/was. I've used the black Toyota filters for the last 62,000 miles and all my UOA are excellent, regardless of the brand of oil.
SilverGlow is offline   Reply With Quote
Old 05-29-2009, 01:04 AM   #3
The little red pill
Taking care of Bubbles
Drives: 2009 Yaris LB "Bubbles"
Sounds like a good idea to just have it checked out. Since it's not a maintenance item, any work should be covered under warranty. Even if not, they are legally bound to provide you with a written estimate before any work is done.
2009 Absolutely Red LB. "Bubbles"
The little red pill is offline   Reply With Quote
Old 06-04-2009, 12:17 PM   #4
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
everything in this statement is incorrect..the black oem filters are 100% fine and will perform just as good as the next alternative...heck i use a cummins fleetguard filter in my car..... ive used royal purple in my car in both engine and transmission and i will continue to use it because it works just fine.
DIY: Intake Installation redyaris DIY / Maintenance / Service 53 08-23-2014 05:34 AM
The last gas question Tonavi DIY / Maintenance / Service 56 04-27-2009 08:40 PM
How would you sound deaden engine compartment? Yawesh General Yaris / Vitz Discussion 11 01-11-2009 03:41 PM
The Advantages of Nitrous on an Engine KCALB SIRAY Performance Modifications 7 01-02-2009 10:53 AM
weird sound yrsdrgn Cosmetic Modifications (Exterior/Interior) 7 02-05-2007 11:47 PM
