Old 05-29-2009, 12:35 PM   #1
Tamago
Tamago's Avatar
Drives: UZJ100
Originally Posted by 1stToyota View Post
No. Heat cracks on pads, brake fade, and discoloring on the rotors is a "HOT" problem, not an uneven cooling issue, of course.
ok smartass, i should have said "heat is not what warps rotors"
Old 05-29-2009, 12:42 PM   #2
1stToyota
1stToyota's Avatar
Okay, smart man that stated that 20wt is thicker than 30wt oil, **rust** is not what caused the OP excessive runout, heat must have warped the rotors...that's why there are machine minimum and discard specs, because less material = more heat, NOT more rust stains...big clue: if "HOT" was a good thing there wouldn't be vented rotors and drums.
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 05-29-2009, 12:47 PM   #3
Tamago
Tamago's Avatar
Drives: UZJ100
i never said a single word about rust in this thread.
Old 05-29-2009, 01:13 PM   #4
1stToyota
1stToyota's Avatar
That's what this thread has been about...assumptions/conclusions that rust overtook the rotor on the dealer's lot within the first 10 miles of life, and that's why the steering wheel shakes while applying the brakes.
Besides, not everybody has the same concept of how hot "HOT" should be, so why risk damage to the rotors and pads, and possible brake fade when the dealer took care of it for free by fixing the runout problem...
2008 Scion xD
Old 05-29-2009, 01:14 PM   #5
Tamago
Tamago's Avatar
Drives: UZJ100
apparently not everyone has the same concept on how dead a horse should be before the beating stops either
Old 05-29-2009, 01:37 PM   #6
1stToyota
1stToyota's Avatar
--apparently not everyone has the same concept on how dead a horse should be before the beating stops either
--getting them HOT does not damage them.
--ok smartass, i should have said "heat is not what warps rotors”
--i never said a single word about rust in this thread
2008 Scion xD
DIY (sorta) - RunStop Rear disc brake conversion eTiMaGo DIY / Maintenance / Service 17 07-02-2019 08:24 AM
DIY Rear Drum Brake Adjustment/Parking Brake W/ PICS Inside YarisSedan DIY / Maintenance / Service 73 03-11-2017 06:05 PM
Dealer: Disabling the seat belt chime is now illegal? schleppy Cosmetic Modifications (Exterior/Interior) 13 04-18-2009 04:43 PM
DIY For radios that require attaching a wire to parking brake Slick DIY / Maintenance / Service 0 04-16-2009 08:14 PM
BIG(GER)TM BRAKE KIT Vanderkitten Performance Modifications 23 01-04-2009 07:16 PM
