Old 06-03-2009, 11:48 PM   #1
The brake booster works off vacuum. Shut the car off, press the brake pedal to the floor. Repeat. If on each additional pump the pedal goes less far the booster is fine. If you can continue to press it all the way to the floor either the check valve or the booster has an issue.
You can check the check valve by removing it and blowing through it. You should be able to blow through the threaded side (that screws into the booster), but not the hose nipple side (that accepts the vacuum line).
The hissing may be a vacuum leak in the hose, the check valve or the booster. The above will help figure out which...
Old 10-22-2010, 07:49 PM   #2
jamal1984
The Beautification of Car
Drives: Toyota Yaris S
Send a message via MSN to jamal1984
i'm planning to do some Seafoam Engine Treatment in my car, and the easy way is to taking the vacuum line from your brake booster PCV. can anyone tell me where is this vacuum line at?
thank you
jamal1984 is offline   Reply With Quote
Old 10-22-2010, 08:57 PM   #3
thank you
It's just to the left of the brake fluid reservoir.
Old 05-04-2012, 12:51 PM   #4
Geoff Peace
Drives: Yaris 1.33 litre 2011
Agree with the above. Also with the engine switched off press the brake pedal several times to exhaust the servo. (brake booster in US I think) Then with firm pressure on the brake pedal start the engine, the brake pedal should go down a little further as the servo assists the foot pressure. If this is so all is fine. The servo is simply two chambers with a diaphragm between. When in use, one side is in vacuum, exhausted by the inlet manifold, the other is normal air pressure which provides the assistance.
Regards Geoff Peace.
Geoff Peace is offline   Reply With Quote
DIY (sorta) - RunStop Rear disc brake conversion eTiMaGo DIY / Maintenance / Service 17 07-02-2019 08:24 AM
DIY Rear Drum Brake Adjustment/Parking Brake W/ PICS Inside YarisSedan DIY / Maintenance / Service 73 03-11-2017 06:05 PM
Dealer: Disabling the seat belt chime is now illegal? schleppy Cosmetic Modifications (Exterior/Interior) 13 04-18-2009 04:43 PM
DIY For radios that require attaching a wire to parking brake Slick DIY / Maintenance / Service 0 04-16-2009 08:14 PM
BIG(GER)TM BRAKE KIT Vanderkitten Performance Modifications 23 01-04-2009 07:16 PM
