the next person that uses the term "slap on" in the same sentence as "turbo" needs a permaban.
SIPNDEW
spectacle needs a permaban..........we already have enough bs on the forum as is.
#3 | |
Maybe in 3-5 years, when a lot more people have tried and either succeeded or failed, the question can be answered with some data to back it up.
Its a first.
SIPNDEW
bench racing = real-life, knuckle-skinning experience, didn't y'all know? that's why we can "slap on" turbos and coilovers....
lol @ the bashing on spectacle.
![]() ![]() Drives: 1990 Supra Turbo Join Date: May 2009
I don't have any experience with a Yaris, let alone a turbo one. But, I do have a turbo supra.
Here are some of the basics that I know about Turbo cars. Please let me know if I am wrong though. -A car with a Turbo stock will have an ECU that is set to retard timing at higher rpm / higher boost. -Turbo cars have much lower engine compression and are better able to handle boost. -NA cars try to achieve a Air/Fuel Ratio of about 14.7, probably richer than that at about 13-14 or less when at full throttle. -A Turbo cars ECU is set to run at 11-12 AFR at full throttle. Running richer allows the gas to cool the piston and reduces the risk of detonation. -Turbo cars usually have some or all of the rotating assembly forged. So, basically, running a turbo without any modifications on an economy engine, you will detonate with AFRs around 14, even at 7psi. I hope someone before me set you guys straight but this thread looks like Honda Tech. It's just horrible. |
#10 | |
when the car goes into open loop mode, larger injectors will provide more than enough fuel to keep boost mode cool
#11 | ||
That's what I was suggesting. |
#12 | |
![]() ![]() ![]() Drives: 2008 Yaris Sedan Join Date: Oct 2008
someone put one of these turbos on the yaris:
http://www.compturbo.com/products/in...&product=CT340 TO4E T3/T4 Hybrid turbocharger with a 40mm Comp wheel stage 1 turbine wheel .36 Non-Port T3 turbine housing. The Triple Ball Bearing version is only $1600. Instant 250hp at low rpm would be nice! |
SIPNDEW
i think people forget that all cars are NOT the same.....a yaris motor is quite different than a turbo supra motor..correct me if im wrong though please.
SIPNDEW
just curious.....do you have a yaris cdavis? if not...why are you here?
yes
SIPNDEW
well welcome aboard.
Bathroom + Laptop = <3
research is golden, if you were trying to bash him, ye lose all chance now... sorry mike lol
| Small cars stacked up at dealerships. | freeridelectric | New YARIS Purchase Forum | 11 | 04-24-2009 08:23 AM |
| Small car's name? | yaris-me | Off-topic / Other Cars / Everything else Discussions | 13 | 03-29-2009 02:43 PM |
| Small science fiction story I wrote which includes the Yaris. :) | john21031 | Off-topic / Other Cars / Everything else Discussions | 3 | 11-21-2008 12:57 PM |
| How Small Would You Go? | Nigal | General Yaris / Vitz Discussion | 26 | 06-15-2007 08:44 PM |
| small 4ch amp. 4x100rms | ben dover | In Car Entertainment + Electronics (audio / video / alarm) | 2 | 04-08-2007 04:17 PM |
