Old 06-06-2009, 03:28 PM   #19
TheSilkySmooth
TheSilkySmooth's Avatar
Originally Posted by curtqn View Post
I want to chane the radiator coolant of my 2009 Toyota Yaris.
No you dont unless someone pee'd in there or your GF put WW fluid in there - DOI!
Old 06-06-2009, 03:32 PM   #20
TheSilkySmooth
On second thought, I think you need a tuneup, which should be done every 3 months to keep up with the Honda Ricers out there ... I would be willing to do it for around 500 bucks - I'll even put in new copper Champions ;) and remove your restrictive air filter and replace with poly pillow stuffing in a pantyhose FTW!
Old 06-06-2009, 07:51 PM   #21
Bob Dog
DARK PHASE OF THE MOON
Bob Dog's Avatar
Drives: 07 liftback
There are threee basic types of coolant the short lifed green that has been around forever and which lasts about two years, the newer red, good for maybe five years, and the recent pink which your car comes equiped with from the factory and is supposed to laast 100,000 miles. Why mess with it when you will not do any good and there is the small chance that you could do some harm?
Bob Dog is offline   Reply With Quote
Old 06-08-2009, 01:25 AM   #22
anexrx7
Drives: 08 MM HB
Not to mention its not exactly a "cheap" procedure anymore. The normal green stuff is ~$10+ a Gallon, granted the Yaris probably has like 3/4 of a gallon haha.
Edit: Come to think of it, if you're on here asking if just the radiator drain is "good enough" and don't have a service manual.. You're WAY out of your league already. IMO you should have the manual every time you do something new. People ask me how to fix a problem while they were "fixing" another. I ask them whats the manual say?..
anexrx7 is offline   Reply With Quote
Old 06-08-2009, 06:49 AM   #23
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
The manual is that big book in the glove box,read it.
Old 06-09-2009, 02:24 AM   #24
curtqn
Drives: Toyota Yaris
I'm curious because I know some don't have the block drain. I'm glad my yaris does. My car has around 20,000 miles. I drive alot along with a few long trips. I plan to change the coolant when it gets to 30,000 miles. I know it's still early but I just want to keep it in good condition.
curtqn is offline   Reply With Quote
Old 06-09-2009, 04:22 AM   #25
WolfWings
WolfWings's Avatar
No, actually, you don't want to change the coolant early.
Coolant is not engine oil, it's not put to heavy mechanical stress, nor does it wear out anywhere near as fast as engine oil or actual lubricants. It's a coolant, once it's seasoned it's best to leave it until the chemicals wear out (100k miles of use) before changing it.
Coolant is one of the few things where changing it early and often isn't always the best thing.
Old 06-09-2009, 11:06 AM   #26
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
Don't forget to drain and replace the power steering fluid.
Old 06-09-2009, 11:31 AM   #27
POORSHA
POORSHA's Avatar
Drives: 2008 LB
I find replacing the air in the tires with fresh air monthly is best. Remember to do this at night because the air is cooler and more dense.
POORSHA is offline   Reply With Quote
Old 06-09-2009, 02:01 PM   #28
jambo101
jambo101's Avatar
Kale auto parts will have everything you need
http://kalecoauto.com/index.php?main_page=index&cPath=2
Old 06-09-2009, 02:22 PM   #29
curtqn
I believe the Yaris have elect power steering. There is no power steering fluid.
Old 06-09-2009, 04:37 PM   #30
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
Better change the electricity, then. Stale electrons can gum up the wiring.
Old 06-10-2009, 03:41 AM   #31
yaris-me
Learn to Relax
Old 06-10-2009, 09:26 AM   #32
Lewis
Our off road vehicle
Lewis's Avatar
Drives: 2009 Yaris 3dr
changing the driver does the most for performance!
Lewis is offline   Reply With Quote
Old 06-10-2009, 09:48 AM   #33
Kongo-Otto
Drives: '09 Yaris & '10 Auris
And dont forget to check the piston return springs.
Old 06-25-2009, 10:42 AM   #34
N9QGS
N9QGS's Avatar
Send a message via AIM to N9QGS Send a message via Yahoo to N9QGS
I did the engine block value and the valve at the bottom of the radiator, I got very little out of the engine block, and it was very difficult to get at in my opinion. I almost said next time I drain, I am not even going to attempt the engine block, 90+% came from the front drain. I was lucky to get a cup out of the engine block. But go ahead and try it, if your results are very different let me know.
198K Miles
N9QGS is offline   Reply With Quote
Old 06-25-2009, 11:25 AM   #35
auxmike
auxmike's Avatar
Why did you need to mess with the antifreeze on a new car?
DIY: Intake Installation redyaris DIY / Maintenance / Service 53 08-23-2014 05:34 AM
Coolant level when engine cold CB900F2 DIY / Maintenance / Service 4 04-05-2009 11:12 AM
Info regarding Engine change. sheraz2000 General Yaris / Vitz Discussion 5 01-08-2009 12:51 AM
The Advantages of Nitrous on an Engine KCALB SIRAY Performance Modifications 7 01-02-2009 10:53 AM
Engine Coolant Temperature djino General Yaris / Vitz Discussion 18 07-16-2007 12:26 AM
